Redbird Posted April 19, 2005 Posted April 19, 2005 I think my R/R might be going south. Only evidence I have is on the way back from TN my voltmeter was reading as low as 12.8v@ ~4500rpm and dropping to below 11v@ idle. No abnormally high readings, so maybe the stator? It normally reads ~14.5v at anything over 4000rpm and around 12.8 at idle. It returned to normal readings about 20 miles from my house. No problems starting or running the bike. Maybe the voltmeter (escort 8500) is the problem. Quote
Guest rockmeupto125 Posted April 19, 2005 Posted April 19, 2005 Grab another voltmeter and check it out. AND....pull the connection at the regulator apart and clean it. Also...as you said...the detector can only report on the information it has...so if the voltage was low because of poor contact to the detector, that may be it...hence checking with a VOM. Quote
Dion Posted April 19, 2005 Posted April 19, 2005 Got the word on mine yesterday Tim. Stator. Don't have a vm hooked up to mine but I think if the reg is gonna go it's just gonna quit. Mine was acting flaky for a while before it died. Quote
Redbird Posted April 20, 2005 Author Posted April 20, 2005 Grab another voltmeter and check it out. That was my first thought, but it had returned to normal readings before I arrived home. Gonna go over the connectors, including the one the the detector/voltmeter and then see if it happens again. If it were the R/R, I would expect spikes as well as drops in voltage, no? Dion, at least it's a relatively simple fix. Fuck the shop, order the stator and a new gasket and slap it in there. Plug and play, baby....... 8) Quote
Dotetcher Posted April 20, 2005 Posted April 20, 2005 Thanks Warchild. Whats the red goop you put around the cable where it enters the cover? Quote
birdie_xx Posted April 20, 2005 Posted April 20, 2005 Just don't buy the Electrex, right Dale ? :twisted: Cheers, Quote
Dion Posted April 20, 2005 Posted April 20, 2005 You know I'm a lazy ass. The bikes already at the shop and I don't have a trailer or vehical to load it into. Quote
Warchild Posted April 20, 2005 Posted April 20, 2005 Whats the red goop you put around the cable where it enters the cover? Med-High temp RTV silicone of some sort, I can't recall specifically.... Just don't buy the Electrex, right Dale ? :twisted: Correct! :evil: Quote
TOXXIC Posted April 22, 2005 Posted April 22, 2005 My cover leaked oil, and I removed it and put on a new gasket. Still leaks. :? Any chance I'm leaking oil from around one of the bolts? Quote
Hookman49 Posted April 22, 2005 Posted April 22, 2005 You know I'm a lazy ass. The bikes already at the shop and I don't have a trailer or vehical to load it into. Bend over, the stealer is going to rape you!!! If you want, I have a small trailer we can go get it and do it. Ken Quote
Northman Posted April 22, 2005 Posted April 22, 2005 Bend over, the stealer is going to rape you!!! Is that supposed to be a deterrent, Ken? :? Quote
Hookman49 Posted April 22, 2005 Posted April 22, 2005 Bend over, the stealer is going to rape you!!! Is that supposed to be a deterrent, Ken? :? Alas, you are correct Chris. Dion loves it in the ass!!!!! :raped: Ken Quote
Dion Posted April 22, 2005 Posted April 22, 2005 Bend over, the stealer is going to rape you!!! Is that supposed to be a deterrent, Ken? :? Alas, you are correct Chris. Dion loves it in the ass!!!!! :raped: Ken FAG!!!!!!!!!! It should be done today: :thumbsup: Quote
