SLyFoXX Posted May 30, 2003 Posted May 30, 2003 I just installed a NEP throttle lock and I have a question when installed, should the throttle release all by itself, should I need to use my hand to turn the throttle back when the lock is not latched? Not that it is difficult but just want to make sure the thing is installed correct. Quote
SwampNut Posted May 30, 2003 Posted May 30, 2003 When unlatched, the throttle should work just as it normally does. When latched, it should hold but still be moveable with light effort. Note that there is often some molding flash on the inside of the holding part, and it helps to clean it up. Also it will break in after you use it a bit. Adjust it properly, then work the throttle for a minute with the lock latched. Quote
