XXera
5 Neutral
About XXera
  • Birthday 04/01/1947
3,439 profile views
  1. https://youtu.be/LydemFAW2HU
  2. Thanks for the help. I couldn't get all the photos in one thread. Here is a list of the miscellaneous that I hope will go with it instead of trying to sell them separately. PARTS FOR 2000 BLACKBIRD Good lower left and right front cowls Good tail piece Good grab rail Good handlebar switch Electronic box to correct speedometer Fairing parts and horn Rear view mirror parts Power commander Virtually unused original header, pipes, and two mufflers. It has a full micron titanium exhaust system installed now. Battery charger A used dust cover A riding leather suit An aluminum pickup or trailer loading rack Heated vest and pants Misc. bolts and parts
  3. I can send you what it sounds like running but apparently my MOV is too large for this topic.
  4. I bought the Blackbird back in 2000 and it has been a great bike! I'll take $3,500 for the bike and all of the parts. You would have to come and get all of this stuff.
  5. What year Blackbird did you get? I'm fixing to sell my 2000 and all the extra parts I have.
  6. I have really enjoyed the headset. I've recorded just about all of the CD's I have and it has used only just over half the memory! I use it while I am exercising on the back porch. It was in almost new shape. Thanks a lot.
  7. What does the other side of the bracket look like?
  8. Is your case 42" or 42cm? 1500 Case Specifications Exterior Dimensions (L x W x D) Interior Dimensions (L x W x D) 18.50" x 14.06" x 6.93" (47 x 35.7 x 17.6 cm) 16.75" x 11.18" x 6.12" (42.5 x 28.4 x 15.5 cm) Lid Depth Bottom Depth Total Depth 1.81" (4.6 cm) 4.31" (10.9 cm) 6.12" (15.5 cm) Weight w/Foam Weight w/o Foam Buoyancy Max. 7.05 lbs. (3.2 kg) 6.39 lbs. (2.9 kg) 50 lbs. (22.68 kg) Range Temperature (-10 / 210 F) (-23 / 99 C)
  9. I've got a 1999-2000 manual and here is a picture of what I was talking about. If you don't have access to an ohmn meter, then your best probably your best option is to take it to someone.
