The Krypt Keeper Posted May 7, 2004 Posted May 7, 2004 I wanted to check my plugs since I am about due. I ordered some this evening for $8.00 each :wink: and was curious on a couple things. Why are the velocity stacks different heights? I only figured because of the shape the airbox itself. stacks 1 and 4 would need to be lower to allow the same amount of air into them as 2, and 3 sitting nice and pretty in the wide open middle of the box. The ram air tubes aren't really snug fitted together. :???: If you were too put some RTV around them make a tighter seal would it be easier to pressurize your airbox, maybe making a few more ponies in the lower RPM range? Also Honda put so much thought into their airfilter.. would a K&N be better when I go to dyno tune or stay with Honda filters.. I have heard both sides argue this about them.. Just wanna know results other bird owners have had. This is my only thing I own that doesn't have a K&N in it yet. thanks for all the input.. Dave Quote
Northman Posted May 7, 2004 Posted May 7, 2004 The ram air tubes aren't really snug fitted together. If you were too put some RTV around them make a tighter seal would it be easier to pressurize your airbox, maybe making a few more ponies in the lower RPM range? That's what I'm planning on doing on re-assembly. This would help ensure that any ram air effect stays in the airbox, but you'll only see a possible performance gain at very high speeds (150+). If your XX is FI equipped, go ahead with the K&N, but don't expect much or any performance gain, at least when both filters are new. Be careful to not over-oil the filter, either. Quote
The Krypt Keeper Posted May 7, 2004 Author Posted May 7, 2004 Cool deal appreicate the info :wink: I was curious how I am suppose to get a good seal with ramair and get the airbox pressurized they just pop right out and didn't have a very snug fit.. Might see about getting a K&N filter soon than.. if anything it will save me a trip to the stealers when a paper filter would need to be changed.. already have the cleaning kit and oil for all my other K&N filters :wink: Quote
demon Posted May 7, 2004 Posted May 7, 2004 I read that the air box on a bird actually builds more pressure than atmospheric at as low as 90 MPH. From there it keeps climbing up to 28mb over atmospheric pressure at top speed :shock: . Sealing the ram air tubes should be worth a little more pressure at as little as 100mph. I have sealed up the 2 water drain holes and disconnected the PAIR valve. Both these should increase the pressure slightly. Next time I have the tank up, I'm going to silicone the ram air tubes to the airbox. It will be completely sealed. Quote
