Clear lens?
Hurricane
Those look like MIGs on the bike you have pictured under the LED rear lens section... be au ti ful !
What is the black "fender eliminator" under your light? Anyone have a pic up closer of that piece or maybe an opinion of it, where I can get it?
I bobbed mine, but for the winter with all of the sand and shiz on the road, I bought (on Ebay) another stock fender cause the taillight and tip of the tail were getting caked with crud....
need a pretty undertail, mototeck is too much money... but that looks clean (and cheap)...
back to the thread subject... are the LEDs as bright as the bulbs?
I dont even know what I bought... is that a clear lens for the taillight... or is it an entire new assembly?
If it is just the lens... any tricks to taking the red one off and sealing the clear one up tight?
Thanks....
-John
-not to worry on the pics, I'll be all over them......
You bought the whole taillight assembly with LED's built in.
Remove seat and tail cowl then unplug stock taillight assembly and
two 8mm nuts to remove the stock taillight then reverse with new taillight
plugged in. 10 minute job. No glue or sealing needed.
Easy stock replacement.
