Question about Ricks stator
XXera
Has anybody bought a Ricks stator lately for a FI Blackbird, and if so, did you have to modify the insulator grommets, wiring leads, or connectors to get it installed? I have a 2000 Blackbird that appears to have a bad stator and was thinking about a Ricks versus an OEM Honda.
Thanks for any help.
I'm running a Rick's in my 2002, with no problems whatsoever. They put the proper connector on based on the year you buy, and it matches up to the OEM.
That having been said, the connector on mine eventually ended up being loose, got hot and eventually cooked one of the 3 leads. I decided that rather than fuck around with it, I would just cut and solder the wires after putting them together with a western union splice:
It took a while to solder, as those are some big wires and it took a bit to get them hot enough for the solder to flow.
I then covered the wires with heat shrink tubing to keep them from grounding out. So far, it's worked flawlessly.
Thanks for the information. I decided to go ahead and order an OEM stator from Service Honda. If the new one will last as long as the original, that will be good enough for me. Besides, I won't be hitting the rev limiter at the track anymore with Jay.
What's going on, Jay. How's the weather down there?
  • 2 weeks later...
