Pete1651 Posted September 17, 2010 Posted September 17, 2010 Hi, I really hope someone can come to my rescue as I'm at my wits end. I have a 2002 blackbird purchased privatley about a month ago. It seems to be overfueling as I only get 100 miles to a tank, the bike constantly smells of fuel and after a few minutes of warming up the engine cuts out if I let the revs drop. I've tried taking it a Honda dealer to plug into the diagnostic machine, but to no avail. Has anyone experianced anything similar with their Blackbirds? Cheers Pete Quote
Sondance Posted September 17, 2010 Posted September 17, 2010 On my 2000 Bird, I had the constant fuel smell as well, found out by lifting the tank and turning the key that the fuel line connectors were seeping out fuel as the injectors increased pressure within the line and the line expanded. Not noticeable unless you turned the key to engage the FI. I ended up replacing the fuel line and fuel pressure regulator as well and all is well. I didn't have an idle cutoff issue though, and I'd doubt this would solve it. Someone more technical on here can perhaps address this.. Quote
EVLXX Posted September 17, 2010 Posted September 17, 2010 +1 on the seconds post.... NEXT ! Sondance, Same thing. except, if you have had a prolonged exposure to ethanol laden fuels in your area, in which case you might have to replace the main rubber fuel line as well. Quote
Furbird Posted September 17, 2010 Posted September 17, 2010 I would lean more towards the fuel line itself. Mine let go at the crimps, and fuel was leaking out and down the vent hose to the ground. The only way I noticed it was by cranking it up and pulling the plastic piece back on the shifter side of the bike. Then I saw the fuel leaking from the crimp. If the regulator goes out, it's still combusting the fuel as it stays in the vaccuum lines or back to the tank, regardless it stays in the closed loop. Raw fuel smell indicates a leak. Not to mention, if the regulator went out it floods the engine with fuel if it's left sitting for several hours or overnight. That's how I found out mine was bad. Rode home Friday night, Saturday morning I have an engine with fuel overflowing the throttle bodies. Hydrolock! Quote
beestoys Posted September 19, 2010 Posted September 19, 2010 Yes but the popped diaphram will cause it to run extremely rich. Check everything listed above, an easy check on the FPR is to pull the vaccum line if its wet the diaphram is going bad. Quote
uvaldeXX Posted September 20, 2010 Posted September 20, 2010 Fuel pressure regulator. +1 Hell, I had so much unburned fuel accumulate in the mufflers I would have flames coming out the exit pipe! Quote
nybryan Posted September 20, 2010 Posted September 20, 2010 Sounds like a fuel pressure regulator to me also. Good news is its cheap and a real easy job. Quote
