grahamcuk Posted April 19, 2010 Author Share Posted April 19, 2010 This is what I make for the job. Installed with a little Loctite lock&seal. Seems to be working fine. Do those install from the inside or outside? Is Loctite the only thing holding them in? They install from outside. With the lock and seal the only way you will get them out would be to take the motor apart and hammer them out. Quote Link to comment Share on other sites More sharing options...
grahamcuk Posted May 29, 2010 Author Share Posted May 29, 2010 Progress report. The MOT ( road fittness test ) was this morning . She went straight though. First impressions are very good, power delivery is very smooth and pulls clean. I have put 35 miles on her this morning. In the wet the rear wheel just wants to spin all the time in any gear. The handling is nice , it needs a little bit of tweeking to get it spot on, that will come to light more when I can get out in the dry. The brake are aaaaaawwesome , loads of feel and a very positive brake point. Over all I'm very happy with the first little test run. Next plan is to get 5-6 hundred miles on her then drop the oil and check it. then we will be off to the Dyno for final setting up and power testing. __________________ Quote Link to comment Share on other sites More sharing options...
Byrdman Posted May 30, 2010 Share Posted May 30, 2010 Sssssssssssssssssssssexy! Quote Link to comment Share on other sites More sharing options...
