StPeteXX Posted April 20, 2003 Share Posted April 20, 2003 What can anyone tell me about this unit. My '97XX came with one. It also has been jetted and has a Muzzy 4-1 with CF can. Any suggestions on settings and what the anticipated results might be is greatly appreciated. Rich Quote Link to comment Share on other sites More sharing options...
StPeteXX Posted April 20, 2003 Author Share Posted April 20, 2003 I purchased my '97 from a local dealer, so I have not spoken to the prior owner. The prior owner did install a hazard light switch, side luggage and the aformentioned exhaust/ignition items. I have been running premium pump fuel without any problems. I have not tried running anything lower than 93 octane. Rich Quote Link to comment Share on other sites More sharing options...
XX RATED Posted April 21, 2003 Share Posted April 21, 2003 Dyna makes ignitions for most type bikes, especially Kaws. I believe they make complete set-ups with coils and all - simular to Accell, Mallory, ect. The choice of the ignition & a MUZZY exhaust tellsme the former owner may have been a former Kaw guy, rether than a Honda guy. Some guys will enhance the ignition [including the coils] when istalling turbos. to eliminate the spark snuffing that can occur when running high boost. Since a coil problem is almost unheard of on the Bird - the prior owner was experimenting with something. Suggest you take a look at the coils and see if they have been replaced also. If you need more info. on the unit you have - get the serial number off the unit and go to: http://www.dynaonline.com/english/ Hope this helps - Good luck! Quote Link to comment Share on other sites More sharing options...
