NoOne65 Posted July 12, 2008 Share Posted July 12, 2008 When someone talks about drilling the slides what is drilled actually? I dont see anything called a slide in the manual. can anyone enlighten me on this? Quote Link to comment Share on other sites More sharing options...
Mekanix Posted July 12, 2008 Share Posted July 12, 2008 Unless you are HEAVILY modified, I wouldn't bother. In race carbs, I used to drill holes in the butterfly valves to increase air flow at idle. This would prevent opening the butterfly valves beyond idle position and would keep from engaging other circuits at idle. The increased air flow would draw more air thru the venturi circuit, keeping air/fuel correct but the butterflies in idle position. Sets big block idle at about 1000 and only used for racing. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted July 13, 2008 Share Posted July 13, 2008 I think you might be talking about enlarging the hole the vacuum pulls through to move the slide. I think the early models had smaller holes than later. I drilled my 97 per instructions when installing the K&N jet kit. My carbs run perfect. Quote Link to comment Share on other sites More sharing options...
CxBXR Posted July 13, 2008 Share Posted July 13, 2008 I think you might be talking about enlarging the hole the vacuum pulls through to move the slide. I think the early models had smaller holes than later. I drilled my 97 per instructions when installing the K&N jet kit. My carbs run perfect. Yes, this is what I assume also, to reduce the vaccum for jet kit, such as K&N, DynoJet mainly because of the larger jet needle & stiffer slide springs. Quote Link to comment Share on other sites More sharing options...
SR71BLACKBIRDXX Posted July 14, 2008 Share Posted July 14, 2008 Yup..thats what they are referring to. Every jet kit is different though. Some may require it, some dont. When I put a jet kit in my uncles quad, they actually had you drill a second hole in the bottom of the slide. Quote Link to comment Share on other sites More sharing options...
