SC350 Posted May 21, 2008 Share Posted May 21, 2008 My most expensive shipment arrived today... 1. Acrapovic Slip-on mufflers 2. Power Commander III USB 3. K&N air filter I installed everything, used the M113-002 - Erion Racing slip-ons and stock or aftermarket air filter map per tech support at Power Commander Called a local Tuning Center to ask about getting a custom map done for several reasons 1. too-rich = poor fuel mileage 2. too-lean = burnt valves He said it takes about 6 1/2 hours, and he charges $325; does this sound reasonable or am I getting ripped off? Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted May 21, 2008 Share Posted May 21, 2008 My most expensive shipment arrived today... 1. Acrapovic Slip-on mufflers 2. Power Commander III USB 3. K&N air filter I installed everything, used the M113-002 - Erion Racing slip-ons and stock or aftermarket air filter map per tech support at Power Commander Called a local Tuning Center to ask about getting a custom map done for several reasons 1. too-rich = poor fuel mileage 2. too-lean = burnt valves He said it takes about 6 1/2 hours, and he charges $325; does this sound reasonable or am I getting ripped off? Price sounds right. Not sure why he mentioned the time as it doesn't take anywhere near that long. But that maybe how many hours you were going to be charged. Quote Link to comment Share on other sites More sharing options...
TREX Posted May 21, 2008 Share Posted May 21, 2008 My most expensive shipment arrived today... 1. Acrapovic Slip-on mufflers 2. Power Commander III USB 3. K&N air filter I installed everything, used the M113-002 - Erion Racing slip-ons and stock or aftermarket air filter map per tech support at Power Commander Called a local Tuning Center to ask about getting a custom map done for several reasons 1. too-rich = poor fuel mileage 2. too-lean = burnt valves He said it takes about 6 1/2 hours, and he charges $325; does this sound reasonable or am I getting ripped off? Price sounds right. Not sure why he mentioned the time as it doesn't take anywhere near that long. But that maybe how many hours you were going to be charged. a good custom map can take up to 5 hours depending on how many points the dyno operator works on in the throttle openings my map for my 99 bird took 4 and 1/2 hours and my 05 took 4 and 1/4 hours and was mapped for every 250 rpms up the scale and it was totally a different bike afterwards it pays to have a rear tyre that is not new as it takes quite a few runs to get it right and may square the tyre off prematurely the later dyno jet dyno's have a computer helping to get the map done and also use a variable load cell as well they are far removed from the free run dyno's that dyno jet used to do if done properly your air fuel ratio should be spot on all through the rev range and your fuel economy will change as it is a performance mod that you are doing i paid $560 NZ dollars for the 99 and $540 AUSSIE for the 05 custom map and i watched the 05 map being made it was quite an experience to watch and to see 154 rwhp unfold with a totally linear power curve with no dips many operators will just change a few points in an existing map from the data base but get them to build you a custom map from scratch the difference is chalk and cheese as no two bikes are the same and no two will react to the same mods in the same way dyno jet fly people from all over the world to the states to learn to use their gear properly and the course to learn to build a custom map is over a week long with a practical test on a dyno with a bike with no map and you have to build one from scratch and get within a certain percent of the improvement that the in house technician got i have a mate in sydney that has just done this course in the last year sponsored by his employer Quote Link to comment Share on other sites More sharing options...
RC Randy Posted May 21, 2008 Share Posted May 21, 2008 Getting a custom map done on my Busa next week, by a very reputable shop in Kansas City, and they charge $250. I like the Busa, but after riding it, makes you appreciate the more refined Blackbird's fuel injection. Quote Link to comment Share on other sites More sharing options...
CxBXR Posted May 21, 2008 Share Posted May 21, 2008 Price sounds right, 6-1/2 hours does not. As somebody stated already the newer dyno jet has software built in that programs the pc3 without operator assistance, calculates the proper setting's & applies them to the pc3 without all the usual BS. Quote Link to comment Share on other sites More sharing options...
pug Posted May 29, 2008 Share Posted May 29, 2008 Price sounds right, 6-1/2 hours does not. As somebody stated already the newer dyno jet has software built in that programs the pc3 without operator assistance, calculates the proper setting's & applies them to the pc3 without all the usual BS. +1 here from the very other side of Atlantic. New dynojets are doing the job almost automatically. I can e-mail you my map, originally made by the operator but checked next year when the new utilities were available. It is for a K&N filter-o2 elimionator with Termignoni open slip ons (shouldn't be very different than Akrapovic). Quote Link to comment Share on other sites More sharing options...
Ronnie Posted May 29, 2008 Share Posted May 29, 2008 I had custom map made on my 2002 XX Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted May 29, 2008 Share Posted May 29, 2008 If they do have a new dyno jet and a operator that knows what he is doing it doesn't take long at all. I found someone that was quite good and had him tune my map so that less than 10% TS and under 5000RPM is economy. Anything above 10% TPS or above 5000RPM it is configured for best power. I've got a 03 with 2Bros Slip on's, pair removed, and K&N if anyone wants to try the map PM me. I'll gladly send it to ya. Quote Link to comment Share on other sites More sharing options...
SC350 Posted June 5, 2008 Author Share Posted June 5, 2008 The custom mapping is done.... and holy crap. When I'm quick on the throttle the rear starts going sideways. Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted June 5, 2008 Share Posted June 5, 2008 send it!!! Quote Link to comment Share on other sites More sharing options...
R1000 Posted June 6, 2008 Share Posted June 6, 2008 The custom mapping is done.... and holy crap. When I'm quick on the throttle the rear starts going sideways. Is your Bird shaft driven Quote Link to comment Share on other sites More sharing options...
GadgetXX Posted June 7, 2008 Share Posted June 7, 2008 If they do have a new dyno jet and a operator that knows what he is doing it doesn't take long at all. I found someone that was quite good and had him tune my map so that less than 10% TS and under 5000RPM is economy. Anything above 10% TPS or above 5000RPM it is configured for best power. I've got a 03 with 2Bros Slip on's, pair removed, and K&N if anyone wants to try the map PM me. I'll gladly send it to ya. I have the same setup. 2003, K&N, Pair removed with 2 Bros CF Slipons. I would like to campare your map to the one I had done and see how close they are. The guy that did my custom map really took the time to make sure it was done right. It would be intersting to see how close they are. Mike Quote Link to comment Share on other sites More sharing options...
TJ1137 Posted June 7, 2008 Share Posted June 7, 2008 Does anyone know a shop that is around Chicago that is good with custom maps for the BB?? Quote Link to comment Share on other sites More sharing options...
TJ1137 Posted June 10, 2008 Share Posted June 10, 2008 Bump... Quote Link to comment Share on other sites More sharing options...
