BlueBlackBird Posted April 21, 2008 Share Posted April 21, 2008 Ok Ive got all the old stuff off, shock , spring and all cleaned up.(Im using stock shock) Im reading the manual that comes with the Hyperpro and it looks as though the progressive(tightly wound) part of the spring should be UP(even the printing of the name(Hyperpro) on the spring would be right side up). However when configured this way the stock plastic protector on the bottom of the shock will not fit through the new spring , but when I reverse the spring , that is to say put the tightly wound part down , the plastic protector slides on nicely. The manual that comes with the hyperoro loses a bit in translation it seems to me. I sure dont want to mount it incorrectly, so all the Europeans can just chime in and help, also the North Americans too!! Thanks in advance Quote Link to comment Share on other sites More sharing options...
speedygeezer Posted April 21, 2008 Share Posted April 21, 2008 Ok Ive got all the old stuff off, shock , spring and all cleaned up.(Im using stock shock) Im reading the manual that comes with the Hyperpro and it looks as though the progressive(tightly wound) part of the spring should be UP(even the printing of the name(Hyperpro) on the spring would be right side up). However when configured this way the stock plastic protector on the bottom of the shock will not fit through the new spring , but when I reverse the spring , that is to say put the tightly wound part down , the plastic protector slides on nicely. The manual that comes with the hyperoro loses a bit in translation it seems to me. I sure dont want to mount it incorrectly, so all the Europeans can just chime in and help, also the North Americans too!! Thanks in advance FWIW, the one I installed has the Hyperpro logo upside down...... Quote Link to comment Share on other sites More sharing options...
kiwimack Posted April 22, 2008 Share Posted April 22, 2008 Ok Ive got all the old stuff off, shock , spring and all cleaned up.(Im using stock shock) Im reading the manual that comes with the Hyperpro and it looks as though the progressive(tightly wound) part of the spring should be UP(even the printing of the name(Hyperpro) on the spring would be right side up). However when configured this way the stock plastic protector on the bottom of the shock will not fit through the new spring , but when I reverse the spring , that is to say put the tightly wound part down , the plastic protector slides on nicely. The manual that comes with the hyperoro loses a bit in translation it seems to me. I sure dont want to mount it incorrectly, so all the Europeans can just chime in and help, also the North Americans too!! Thanks in advance FWIW, the one I installed has the Hyperpro logo upside down...... eerrrr mine is too, but I do come from down under, Quote Link to comment Share on other sites More sharing options...
airborneXX Posted April 22, 2008 Share Posted April 22, 2008 Ok Ive got all the old stuff off, shock , spring and all cleaned up.(Im using stock shock) Im reading the manual that comes with the Hyperpro and it looks as though the progressive(tightly wound) part of the spring should be UP(even the printing of the name(Hyperpro) on the spring would be right side up). However when configured this way the stock plastic protector on the bottom of the shock will not fit through the new spring , but when I reverse the spring , that is to say put the tightly wound part down , the plastic protector slides on nicely. The manual that comes with the hyperoro loses a bit in translation it seems to me. I sure dont want to mount it incorrectly, so all the Europeans can just chime in and help, also the North Americans too!! Thanks in advance FWIW, the one I installed has the Hyperpro logo upside down...... eerrrr mine is too, but I do come from down under, And the coils are wound the opposite way I'll go look in a little while, but I vaguely remember coming across the same thing and just installing it the way it fits. Quote Link to comment Share on other sites More sharing options...
