lensmanxx Posted November 5, 2007 Share Posted November 5, 2007 I'll be wintering my '97 Bird soon. Can I reach the float bowl drain screws without having to remove the carb bank from the manifold? I prefer doing that as opposed to just running gas with Stabil in it through them. Quote Link to comment Share on other sites More sharing options...
R1000 Posted November 5, 2007 Share Posted November 5, 2007 I'll be wintering my '97 Bird soon. Can I reach the float bowl drain screws without having to remove the carb bank from the manifold? I prefer doing that as opposed to just running gas with Stabil in it through them. Yes you will access the fuel drain screws on bottom/side of carbs after removing the side fairings. I do the same. Quote Link to comment Share on other sites More sharing options...
MontanaXX Posted November 7, 2007 Share Posted November 7, 2007 I'll be wintering my '97 Bird soon. Can I reach the float bowl drain screws without having to remove the carb bank from the manifold? I prefer doing that as opposed to just running gas with Stabil in it through them. Yes you will access the fuel drain screws on bottom/side of carbs after removing the side fairings. I do the same. +1 Quote Link to comment Share on other sites More sharing options...
