BlueBlackBird Posted September 19, 2007 Share Posted September 19, 2007 While replacing my counter shaft sprocket and cleaning the area, the clutch push rod pin came out abit far, and now I cant seem to push it back in, Am I screwed or what, Im longing for a simple solution!! Any ideas out there? Quote Link to comment Share on other sites More sharing options...
testrider Posted September 20, 2007 Share Posted September 20, 2007 Have you tried to put the cover back on? It may look like it's too far out but it isn't. I just replaced my front sprocket too and I pulled the rod all the way out of the engine, cleaned and lubricated it and pushed it back. It did look like it's sticking out too much but when you put the cover back on, it was fine. Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted September 20, 2007 Share Posted September 20, 2007 Iv'e only had mine out twice. Cleaned and went right back in. Could you have grabbed the clutch lever? Is the slave cylinder pushed out, preventing you from fitting it together? Try pushing the cylinder back in. YOu could also release the bleed valve on the slave if necessary. Quote Link to comment Share on other sites More sharing options...
BlueBlackBird Posted September 20, 2007 Author Share Posted September 20, 2007 Thanks, problem solved, yes it does go back with the cover back in place, I didnt want to take the persueder to it Thanks for the info Danny!! Quote Link to comment Share on other sites More sharing options...
