John01XX Posted August 27, 2007 Share Posted August 27, 2007 I received this PM from a Bird Rider in Hungary. If anyone knows of a possible solution, I will forward it on to him. If you can spend a little time for me, I forward my question to you : Is there a typical solution to solve the following tecnical problem ('04XX)? : My dim switch doesn't work, it means the tail light don't light up, when I switch it, and (!!) my main light doesn't work too. (I replace the H7 lights) May be the controll relay went wrong ??? Quote Link to comment Share on other sites More sharing options...
cbrbear Posted August 27, 2007 Share Posted August 27, 2007 check the fuse... Quote Link to comment Share on other sites More sharing options...
