therealshake Posted July 19, 2007 Share Posted July 19, 2007 HI everyone. I just bought a 2000 xx and i'm having a problem. the bike is running extremely rich. i can smell gas coming out the tailpipes. the bike bogs down when i pull off in 1st gear and cuts out/ surges @ 3500 rpm's. my mechanic tells me there is no fault code on the FI. any ideas or guidance is greatly appreciated. BTW... I'm 53 yrs old and I'm glad to be here. thanks, therealshake Quote Link to comment Share on other sites More sharing options...
MrBadExxample Posted July 19, 2007 Share Posted July 19, 2007 Does your bike have an aftermarket fuel management system like the Power Commander? Has the bike been unused for an extended period of time, which might cause an injector to be stuck open? If you have a mechanic's stethoscope you should be able to hear each injector clicking as it opens/closes. Add a can of Sea Foam to your next tankful. It seems to be fairly effective at cleaning out fuel systems. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted July 19, 2007 Share Posted July 19, 2007 Did the bike sit for a long time before you bought it? If so, you might be looking at a stuck injector. Don't fool with this too long...washing down a cylinder with gas and diluting the oil isn't really good for it. Sounds like you could start with a good tune-up and inspection of components before you do much else, youngster. Quote Link to comment Share on other sites More sharing options...
MrBadExxample Posted July 19, 2007 Share Posted July 19, 2007 Beat ya to it, Joe! Damn you're gettin' slow. Actually according to the times, it's a simulapost. Quote Link to comment Share on other sites More sharing options...
airborneXX Posted July 19, 2007 Share Posted July 19, 2007 IIRC a few others had this same symptom and it was the fuel pressure regulator. Here's a thread... Fuel pressure regulator Quote Link to comment Share on other sites More sharing options...
therealshake Posted July 19, 2007 Author Share Posted July 19, 2007 IIRC a few others had this same symptom and it was the fuel pressure regulator. you're great!!! it was the fuel pressure regulator!!! thanks for the help Quote Link to comment Share on other sites More sharing options...
airborneXX Posted July 19, 2007 Share Posted July 19, 2007 IIRC a few others had this same symptom and it was the fuel pressure regulator. you're great!!! it was the fuel pressure regulator!!! thanks for the help You're welcome. I'm going to take a nap now. Quote Link to comment Share on other sites More sharing options...
