kev7xx Posted May 19, 2007 Share Posted May 19, 2007 I am tring to remove the sprocket on my 2003 CBR1100xx, and I am having problems removing the bolt that holds the sprocket. Doe's anyone know if this is reverse threaded or forward threaded? Thanks Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted May 19, 2007 Share Posted May 19, 2007 Its standard thread. Counterclockwise to loosen. Either: A: use an impact wrench B: put a breaker bar on it, take up the slack, and wack the bar with a good sized hammer C: place a piece of 2x4 wrapped in a towel across the swingarm and let the spoke of the wheel rest on it. If you've already removed the chain, simply put it back on and tie the bottom run together with a wire. It won't slip if you snug the chain up to even moderately tight. You're not making much torque. Quote Link to comment Share on other sites More sharing options...
