Venus97 Posted January 2, 2007 Share Posted January 2, 2007 Hey Guys, I was thinking of getting a jet kit for my Bird and was wondering if there are certain brands I should look for, or avoid. Thanks. Quote Link to comment Share on other sites More sharing options...
86gn Posted January 2, 2007 Share Posted January 2, 2007 I used a Factory Pro jet kit with good results. Quote Link to comment Share on other sites More sharing options...
bartonmd Posted January 2, 2007 Share Posted January 2, 2007 I used a Factory Pro jet kit with good results. Yep... Every Dynojet kit I've used, I have not been able to get rid of the bog off idle, but the Factory pro kit worked Perfectly, and still gets good mileage! Mike Quote Link to comment Share on other sites More sharing options...
sokanxx Posted January 2, 2007 Share Posted January 2, 2007 I have a Dyno Jet, I also have a slight bog off idle. the flat spot in mid range is eliminated but i do have a slight bog off the bottom Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted January 2, 2007 Share Posted January 2, 2007 I have the Dyno Jet kit with perfect results. Quote Link to comment Share on other sites More sharing options...
blackmax Posted January 3, 2007 Share Posted January 3, 2007 I have a Factory Kit on my 97 with a K&N filter and 4 into 1 with a Two Brothers counter measure can. It still gets 40 mpg . Quote Link to comment Share on other sites More sharing options...
06Busa Posted January 4, 2007 Share Posted January 4, 2007 Factory is much more adjustable. factory pro site Quote Link to comment Share on other sites More sharing options...
Venus97 Posted January 5, 2007 Author Share Posted January 5, 2007 Thanks for all the suggestions. (Seems like everything is due at once- tires, valve adjustment, chain/sprockets in the not too distant future) Quote Link to comment Share on other sites More sharing options...
