tripledigits Posted November 10, 2006 Share Posted November 10, 2006 I've owned my '02 since August, and just discovered it has an 18 T front sprocket. It's geared too tall for my liking, and I was going to put a 16 T on, assuming it had the stock 17 T. I wanted to get some input from the guys who have run a 16. I run canyons with my bike, as well as commute on the superslab. Is freeway riding with a 16 pleasant? Thanks for any input. I didn't find much info on this during a search. Jeff Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted November 10, 2006 Share Posted November 10, 2006 16T gives alot better pickup, gas millage will take a hit and your speedo will be out about 15% from 18T. Slabing it with a 16T ups the RPM about 15% compaired to the 18 you had. If you slab alot you might want to try in the middle first before going to 16. I had the 17T on factory, went down to a 16T now I'm going to go up to a 18T as I don't need the power and want the gas millage back. Quote Link to comment Share on other sites More sharing options...
tripledigits Posted November 10, 2006 Author Share Posted November 10, 2006 16T gives alot better pickup, gas millage will take a hit and your speedo will be out about 15% from 18T. Slabing it with a 16T ups the RPM about 15% compaired to the 18 you had. If you slab alot you might want to try in the middle first before going to 16. I had the 17T on factory, went down to a 16T now I'm going to go up to a 18T as I don't need the power and want the gas millage back. Thanks for the input. How much did mileage suffer with the 16T? Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted November 10, 2006 Share Posted November 10, 2006 At least 10% but some of that is from the fun factor.... I'm getting shitty millage right now I need a custom map for my PC3.... Quote Link to comment Share on other sites More sharing options...
