Ever do a valve job?
ndzr
You need to be a capable mechanic to do valves yourself. My bike passed 43k miles and I did not touch the valves. I asked my local honda dealer how much they would charge for valves check and the manager told my the bike does not need one. He said he would reccomend checking compression first before touching the valves. My take if the bike runs well do not mess with the valves. Most of the people who did check valves did not have to make any adjustments. On the other hand the manager is the same guy who, when asked about VFR, told me the bike is the pig and I should not even think about getting one :icon_rolleyes:
Just wondering if any of you do-it-yourselfers have done your own valve job on the bird. I hear its a tricky thing - just wondering if that's true?
Do you mean a "valve job" or do you mean "checking/adjusting valve lash/clearance?" A "valve job" involves grinding new seats for the valves, so they seal better...
Mike
If he was referring to the 2002 and onward Viffers, I can understand why he would say that.
ndzr - checking the valves on the XX is (relatively) trivial... the bulk of the work involves removing tupperware/components to actually get to them:
IPB Image
It's only when you have to actually *adjust* a valve clearance that things become a bit more involved.... you gotta yank the cams to do that.
...He said he would reccomend checking compression first before touching the valves. My take if the bike runs well do not mess with the valves. Most of the people who did check valves did not have to make any adjustments. ...
I have owned my XX only a few months so I am still familiarizing myself with the bike, and its maintanence schedule. First I see in the service manual that I need to change my oil after 8,000 miles [wtf], then after reading old and new posts here, I find that my valves probably won't need to be adjusted until at least 40k. I will be changing my oil much sooner than the book says but I am glad to learn that the valves stay in spec for so long.
This maintanence schedule is so very different from my other bikes. My old FJ requires a few shim changes each spring [3-4,000 miles], and my KTM 450 needs a valve adjustment every 20 hours or so. The dirt bike is obviously a completely different animal, but how is it the Honda can go so long without requiring valve adjustments?
Good metal in the valves and seats, and plenty of valve guide to keep the valve from rocking back and forth as it opens and closes.
Long [tall] valve guides makes sense to me. My KTM must have soft seats and/or short guides because many owners who subject their bikes to race conditions have to replace valves every other season.
  • 1 month later...
Before doing valves, do a leakdown test. Then do it with some oil in the cylinder to confirm it is valves.
And yeah, there is good metal in them there valves and seats, but they both do pit/chip under heavy/hard use. Leakdown will tell the tale, however.
I still think there is some confusion in this thread. To the original poster:
Are you referring to a "valve job" or a "valve adjustment"? Two totally different animals!!
I think most of those high reving 4 stroke singles are just hard on parts. I have heard of several 250 honda that need head work after the first season of a few races. I suspect there is very little valve seat area on that style of motor to begin with and some spend a lot of time wide open . My brothers 525 needed new valves in less then a year. I think it might have had something to do with flat dirt roadrace track , or mabe its the slicks and the go cart track :icon_think:
The parts in those beasts are so tiny and light you just cant expect them to last that long. The bird is very overbuilt for the power it makes .
Herb
I think most of those high reving 4 stroke singles are just hard on parts. I have heard of several 250 honda that need head work after the first season of a few races. I suspect there is very little valve seat area on that style of motor to begin with and some spend a lot of time wide open . My brothers 525 needed new valves in less then a year. I think it might have had something to do witha flat dirt roadrace track , or mabe its the slicks and the gocart track :icon_think:
Herb
I'm going to check mine this weekend since the bike is half apart waiting for parts. 37,000 miles hopefully I'm just killing time.
Edit to ask: Should I order a new gasket kit?
Have you checked your valves? Were they in spec or out?
Thanks.
-mike-
Yes. They were all dead center of spec except for one of the #4 exhaust valves which was a little tight, but still within spec.
