Byrdman Posted August 18, 2006 Share Posted August 18, 2006 Okay ladies, I need a new PCIII map. For an 02' with a K&N air filter and an Akrapovic full exhaust system. Anyone got one? If not, what's close? Eric, Jeremy, talk to me..................... Quote Link to comment Share on other sites More sharing options...
SD Marc Posted August 18, 2006 Share Posted August 18, 2006 http://www.powercommander.com/113-211.aspx Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted August 18, 2006 Share Posted August 18, 2006 "2003 Honda CBR1100XX Modified Micron slipon exhaust base map 113-006 Yosh full RS-3 exhaust Stock air filter" I've got a custom made map for above setup. was donated by a member when I was going to setup a site with a list of maps but it's the only one I got donated so I didn't bother. Let me know if you want to try it. Quote Link to comment Share on other sites More sharing options...
lois Posted August 18, 2006 Share Posted August 18, 2006 How about a map for my PCIIIusb on my 01 ?????? Quote Link to comment Share on other sites More sharing options...
Byrdman Posted August 18, 2006 Author Share Posted August 18, 2006 Jer, you got what I need yo? Quote Link to comment Share on other sites More sharing options...
Warp11XX Posted August 22, 2006 Share Posted August 22, 2006 "2003 Honda CBR1100XX Modified Micron slipon exhaust base map 113-006 Yosh full RS-3 exhaust Stock air filter" I've got a custom made map for above setup. was donated by a member when I was going to setup a site with a list of maps but it's the only one I got donated so I didn't bother. Let me know if you want to try it. Too bad that project didn't get any real response... :icon_thumbsdown: it could help a buncha folks for cheap.... That was my map that I sent you....still working well and I have no complaints at almost 19,000 miles...still as strong and smooth as she has always been. Note: I found no real advantage to turning on the accell pump option with this map for daily driving/commuting. If it does anything worthwhile, it would take some really aggressive throttle application to bring it out. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted August 22, 2006 Share Posted August 22, 2006 I keep my accell pump turned on. Never ridden with it off however. Normally my bike isn't used for commuting. So its is probably getting a light workout on my normal riding aventures. I did notice in the mountains that I wasn't needing to shift gears as often to pull some hills that I normally would click down once to get some extra R's going. Quote Link to comment Share on other sites More sharing options...
Yakasuko Posted August 24, 2006 Share Posted August 24, 2006 Okay!! How difficult is it to install a power commander????? I have a 00 blackbird, any help???? Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted August 24, 2006 Share Posted August 24, 2006 Okay!! How difficult is it to install a power commander????? I have a 00 blackbird, any help???? VERY Easy.... Plug and play pretty much. One connector, and a ground. Quote Link to comment Share on other sites More sharing options...
Yakasuko Posted August 24, 2006 Share Posted August 24, 2006 Okay!! How difficult is it to install a power commander????? I have a 00 blackbird, any help???? VERY Easy.... Plug and play pretty much. One connector, and a ground. Thanks, I think I will try install myself instead of paying for it... Quote Link to comment Share on other sites More sharing options...
willxx23 Posted August 24, 2006 Share Posted August 24, 2006 Okay!! How difficult is it to install a power commander????? I have a 00 blackbird, any help???? VERY Easy.... Plug and play pretty much. One connector, and a ground. Depends on which model you install. PC-2 will be easier than the new PC-3. The new PC-3 has connections at each injector, TPS,MAP, and of course power connection as well. A litlle more involved but all in all not real tough to install with the tank propped up. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted August 24, 2006 Share Posted August 24, 2006 Okay!! How difficult is it to install a power commander????? I have a 00 blackbird, any help???? VERY Easy.... Plug and play pretty much. One connector, and a ground. Depends on which model you install. PC-2 will be easier than the new PC-3. The new PC-3 has connections at each injector, TPS,MAP, and of course power connection as well. A litlle more involved but all in all not real tough to install with the tank propped up. I've got a PC3 USB It has one connector to wiring harness and the ground. WTF PC do you have that makes connectors at the injectors etc? Quote Link to comment Share on other sites More sharing options...
willxx23 Posted August 24, 2006 Share Posted August 24, 2006 I've got a PC3 USB It has one connector to wiring harness and the ground. WTF PC do you have that makes connectors at the injectors etc? The brand new PC-3 USB for 99-00 birds is different. Got mine from Dynojet when they were doing the R&D for it. Can you say "freebie"? PC-2's are "old school" now. Quote Link to comment Share on other sites More sharing options...
EVLXX Posted August 25, 2006 Share Posted August 25, 2006 Sorry Big Guy.... I can't help you with the PC3. Or at least I don't think so........ Quote Link to comment Share on other sites More sharing options...
Red J Posted August 26, 2006 Share Posted August 26, 2006 Jer, you got what I need yo? Sorry, homie. Just now seeing this. I got a jet kit I can send ya... Quote Link to comment Share on other sites More sharing options...
Byrdman Posted August 27, 2006 Author Share Posted August 27, 2006 Will the jets fit into my injectors somewhere? Quote Link to comment Share on other sites More sharing options...
Red J Posted August 27, 2006 Share Posted August 27, 2006 Will the jets fit into my injectors somewhere? Tape them to the nozzle. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted August 27, 2006 Share Posted August 27, 2006 Will the jets fit into my injectors somewhere? Tape them to the nozzle. Come on everyone knows the gas will eat the glue on the tape. You need to use JB Weld to hold them on right... Quote Link to comment Share on other sites More sharing options...
Byrdman Posted August 28, 2006 Author Share Posted August 28, 2006 Ooooh, Timmy's real good with that JB Weld stuff, I'll get him to do it for me. Quote Link to comment Share on other sites More sharing options...
Hobicus Posted August 28, 2006 Share Posted August 28, 2006 Jeff, I think that Justin's got a PCIII which has that exact map on it. Supposedly it's great for power, but not so great for mileage. Quote Link to comment Share on other sites More sharing options...
