Mr.XX Posted August 15, 2006 Share Posted August 15, 2006 Last night I was trying to get the carbs off of my engine and the wouldnt come off Is ther some kind of trick or something that I may have missed ?? I loosened all the clamps that I can see and figured it should come right off but that sucker is stuck tight and since I have never taken them off before I want to make sure I didnt miss something that i might F'up by applying forcre to it anyone? Bueller? Quote Link to comment Share on other sites More sharing options...
MR. WOMO Posted August 15, 2006 Share Posted August 15, 2006 I removed my carbs about a week ago for the first time as well. They needed to be rocked back and forth a bit to free 'em up - but I didn't have a problem. Some of the more knowledgeable guys may have additional insight, but I can't think of why they'd be stuck. -Kevin Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted August 15, 2006 Share Posted August 15, 2006 They are a lilttle hard to get off. Rock them. There was one guy a while back that never did get them off. He ended up working on the carbs on the bike. Not me. Quote Link to comment Share on other sites More sharing options...
airborneXX Posted August 16, 2006 Share Posted August 16, 2006 Try to spray WD40 around the ends of the rubber boots and let it soak. Same for install spray some WD around the inside of the boots and the carbs will pop right on. Quote Link to comment Share on other sites More sharing options...
Mr.XX Posted August 16, 2006 Author Share Posted August 16, 2006 Try to spray WD40 around the ends of the rubber boots and let it soak. Same for install spray some WD around the inside of the boots and the carbs will pop right on. Funny I was thinking of trying that .... Quote Link to comment Share on other sites More sharing options...
airborneXX Posted August 17, 2006 Share Posted August 17, 2006 Well did ya get 'em off? Quote Link to comment Share on other sites More sharing options...
Mr.XX Posted August 17, 2006 Author Share Posted August 17, 2006 Nope, I tried again last night .... those suckers are stuck tight ... I am rocking , wiggling and pulling on em but they wont come off And yes I did spray them with WD-40 Quote Link to comment Share on other sites More sharing options...
airborneXX Posted August 17, 2006 Share Posted August 17, 2006 Nope, I tried again last night .... those suckers are stuck tight ... I am rocking , wiggling and pulling on em but they wont come off And yes I did spray them with WD-40 But did you try cussing at them? Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted August 17, 2006 Share Posted August 17, 2006 get a small tapping tool.. if that don't work get a larger tapping tool Alot of times that will be stuck and stubborn and need some cussing.. Spray them down with some PB blaster and let them soak over night. if that don't work get a small propane torch and try heating them up some Just kidding about the torch.. Quote Link to comment Share on other sites More sharing options...
Mr.XX Posted August 18, 2006 Author Share Posted August 18, 2006 tapping tool ????? Quote Link to comment Share on other sites More sharing options...
MileHi Posted August 18, 2006 Share Posted August 18, 2006 tapping tool ????? AKA HAMMER!!! Quote Link to comment Share on other sites More sharing options...
airborneXX Posted August 18, 2006 Share Posted August 18, 2006 Something along this line should do it Quote Link to comment Share on other sites More sharing options...
BearXX Posted August 18, 2006 Share Posted August 18, 2006 Dynamite might take them off.... Quote Link to comment Share on other sites More sharing options...
TechnoGecko Posted August 19, 2006 Share Posted August 19, 2006 They are a lilttle hard to get off. Rock them. There was one guy a while back that never did get them off. He ended up working on the carbs on the bike. Not me. That was me. Tried to remove the carbs from the bike to rejet it but never could get them off. Rocked them for hours on end to no avail. Even tied a rope to them and then to a pulley on the ceiling.... the bike started to pull off the ground and yet the carbs still stayed on. Ended up saying fuck it and was able to do it very carefully without removing them. God forbid I ever need to remove them, it's going to the dealer - because there is no way in hell I can get them off.... Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted August 20, 2006 Share Posted August 20, 2006 Even tied a rope to them and then to a pulley on the ceiling.... the bike started to pull off the ground and yet the carbs still stayed on. Sorry about the laugh but that's just funny. Quote Link to comment Share on other sites More sharing options...
Mr.XX Posted August 21, 2006 Author Share Posted August 21, 2006 They are a lilttle hard to get off. Rock them. There was one guy a while back that never did get them off. He ended up working on the carbs on the bike. Not me. That was me. Tried to remove the carbs from the bike to rejet it but never could get them off. Rocked them for hours on end to no avail. Even tied a rope to them and then to a pulley on the ceiling.... the bike started to pull off the ground and yet the carbs still stayed on. Ended up saying fuck it and was able to do it very carefully without removing them. God forbid I ever need to remove them, it's going to the dealer - because there is no way in hell I can get them off.... Wow .... I havent gone that far but I bet I would have the same results I am going to stop by the parts place and get a feeler gauge and try and slip a blade up in there to break it loose .... I am hoping that if I can get one or two loose the others will rock off easier :icon_wall: the good news is I am pulling these off of my old/wrecked bike to exchange on the one I am riding since they are already jetted ... I hope the other set comes off eaiser than these. I wanna do the swap before NEXXT Quote Link to comment Share on other sites More sharing options...
