Keith Posted September 17, 2006 Author Share Posted September 17, 2006 When you say the windings of your stator still have the same readings as your old, do you mean the .2 ohm resistance? or you're getting voltages out of them that are unequal and less than 50V? Sorry about that; I should have been more specific. The windings showed the same 0.2 ohm reading as the dead stator. Since I had good charge voltage after installing the new stator, I did not check the A/C output of the stator; I should probably do that, if for no other reason than to have the baseline readings from a new unit. Quote Link to comment Share on other sites More sharing options...
