Amherst XX Posted July 15, 2006 Share Posted July 15, 2006 Checked my carbs today (with a manometer). They are off by a significant margin. Now I need to find the adjustment screws for the #1, #2, and #4 carbs. The shop manual that I have (Honda) tells you how to adjust them but is very vague on their locations. Thanks Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted July 15, 2006 Share Posted July 15, 2006 Get yourself a L O N G phillips screwdriver. they are located on the shaft that pases through all the carb butterflys, between each carb. You'll need a flashlight also. Quote Link to comment Share on other sites More sharing options...
Amherst XX Posted July 16, 2006 Author Share Posted July 16, 2006 Thanks man, that cleared it up. Good way to spend an afternoon...drinking and sync-ing carbs. I did my B-Bird, my father-in law's V45 Magna and my wife's FZ600. The Magna was the hardest by far. The Blackbird wasn't so bad once I knew where the screws were. Thanks for the prompt help. As always, you folks are as valuable a resource for technical info as you are for porn Cheers. Quote Link to comment Share on other sites More sharing options...
