Elefant Posted June 3, 2006 Share Posted June 3, 2006 How the hell do I get to it? Search's turned out empty.... Quote Link to comment Share on other sites More sharing options...
gourmet Posted June 3, 2006 Share Posted June 3, 2006 There is a screw under the the whole mirror/signal casing. Also flip back the protective rubber casing between the bike and the mirror casing. Undo the top screw. slide whole unit out and remove bulb from the back of the unit. Good luck. Brian Quote Link to comment Share on other sites More sharing options...
Obby Posted June 4, 2006 Share Posted June 4, 2006 If I remember correctly, there is no way in hell that screw under the mirror assembly will come out until you remove the two screws holding it to the upper fairing. That was my experience anyways. My 2 cents. Quote Link to comment Share on other sites More sharing options...
sokanxx Posted June 4, 2006 Share Posted June 4, 2006 True story! that bottom screw isnt going anywhere! slid the rubber boots on the mirror mounts up and there should be two bolts, take out the bolts the mirror slides out and they the signal assembly. dont mess with the screw on the bottom of the mirror you will just strip the screw all up Quote Link to comment Share on other sites More sharing options...
