blkbrdrydr Posted August 1, 2003 Share Posted August 1, 2003 I finally got around to using (or trying to use) the Pit Bull front stand that I got for a Christmas present. I tried to use it to remove my front wheel and found that the side supports of the stand were directly in front of the axle and prevented me from removing the front axle. I ended up putting a car jack under the motor to remove the wheel. Why the fuck doesn't the stand allow for removing the front axle? Quote Link to comment Share on other sites More sharing options...
ConqSoft Posted August 1, 2003 Share Posted August 1, 2003 Sounds like maybe you didn't use it right. I've use the steering stem Pit-Bull and the fork-lift Pit-Bull on my XX and had full access to the axle with both. :?: Quote Link to comment Share on other sites More sharing options...
blkbrdrydr Posted August 1, 2003 Author Share Posted August 1, 2003 Talked to George at Pit Bull this morning. Seems that some of their stands will block the axle of some bikes. I have the Newfront stand which does block the axle of the XX and some Ducati Monsters. George suggested that I try turning the forks to gain room to remove the axle or, if that doesn't work, they will work out an exchange deal with me for a Forklift model that doesn't interfere with the axle on the XX What incredible customer service. WOW Quote Link to comment Share on other sites More sharing options...
ConqSoft Posted August 1, 2003 Share Posted August 1, 2003 How about the Old Front Stand? Or if you get the converter for the fork lift to convert it to a stem-stand? Quote Link to comment Share on other sites More sharing options...
Warchild Posted August 1, 2003 Share Posted August 1, 2003 That sucks. I have the Pit Bull front stand and it works splendidly, doesn't block any aspect of the axle for me. I later got the fork converter to go with it, so now I can remove the forks on the XX and 929RR for fluid changes, overhauls, etc. Maybe Pit Bull will swap you out for one of their standard front stands and converter? Quote Link to comment Share on other sites More sharing options...
blkbrdrydr Posted August 1, 2003 Author Share Posted August 1, 2003 Maybe Pit Bull will swap you out for one of their standard front stands and converter? That's what they offered to do. Mine is the latest and greatest stem stand model. It just is a bad fit for the XX Quote Link to comment Share on other sites More sharing options...
AlphaBird Posted August 1, 2003 Share Posted August 1, 2003 If its the steering stem stand--(new ish one) ---just turn the handlebars/wheel fer heavens sake Quote Link to comment Share on other sites More sharing options...
