davesXX01 Posted January 24, 2006 Share Posted January 24, 2006 Anybody ever run this combo of sprocket? Clearance issues? Chain rubbing? The reason I want to run this is I want better acceleration, just not as much ratio as 16-45 or 17-46 ( smaller sprockets-less weight-fewer links) Dave Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted January 24, 2006 Share Posted January 24, 2006 Unless you are either you are splitting hairs. The difference in ration between the 16-45 and the 16-44 is maybe 1 or 2 hundred rpm. I don't see the point. Quote Link to comment Share on other sites More sharing options...
davesXX01 Posted January 24, 2006 Author Share Posted January 24, 2006 Rockme; #2 is why. You see, 16-45 drops your speed at 4000 rpm 4 mph compared to stock 17-45. 16-44 drops only 2 mph at 4000 rpm. Everybody loves droping 1 tooth in front for the sheer fun it provides but would probably go back to 17 if they went to MegaXX for example to get the better mileage. I would rather find the happy medium, have a little better acceleration and not lose too much mpg. Yes, I already have the front sprocket and the rear will be a Sidewinder to go with the wheel group buy! Dave Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted January 24, 2006 Share Posted January 24, 2006 a Sidewinder to go with the wheel group buy! Curse you, Red Baron! Quote Link to comment Share on other sites More sharing options...
