bonox Posted November 29, 2005 Share Posted November 29, 2005 is the stopper tool required to remove the old cct? the old kwaka i had wouldn't mind if you held the thing in with your hand while undoing the bolts - possibly a bit of a weak spring on a less than 1000cc bike though. is there a substitute for the stopper tool listed in the manual? ie can you use a thin screwdriver?, or be quite rough in filing up a 'tool' out of some sheetmetal? PS, the new CCT comes with a little piece of metal in the seal bolt hole at the top - i take it this is not a stopper tool that can be removed and used on the old one? Giving it a little pull sounds lile all hell will break loose inside if the thing is not installed when the 'pin' comes out. Quote Link to comment Share on other sites More sharing options...
AZITPRO Posted November 29, 2005 Share Posted November 29, 2005 I just pulled the old one out and inserted the new one with the stopper in it, I did not hink it matters when removing the old unit. Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted November 29, 2005 Share Posted November 29, 2005 No biggy. Just unbolt it and remove. Nothing will fall out, etc. Quote Link to comment Share on other sites More sharing options...
bonox Posted November 29, 2005 Author Share Posted November 29, 2005 Thanks guys Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted November 29, 2005 Share Posted November 29, 2005 Incase you haven't got one get a new CCT gasket before you bother pulling the old CCT. Quote Link to comment Share on other sites More sharing options...
John01XX Posted November 29, 2005 Share Posted November 29, 2005 Incase you haven't got one get a new CCT gasket before you bother pulling the old CCT. Â A gasket comes with the new CCT from Honda Quote Link to comment Share on other sites More sharing options...
bonox Posted November 29, 2005 Author Share Posted November 29, 2005 gasket and news bolts+washers comes with the kit, just no 'stopper tool' Quote Link to comment Share on other sites More sharing options...
John01XX Posted November 29, 2005 Share Posted November 29, 2005 gasket and news bolts+washers comes with the kit, just no 'stopper tool' The tool is inserted in the new CCT at the top. Do not pull it out before you install the new CCT Quote Link to comment Share on other sites More sharing options...
bonox Posted November 29, 2005 Author Share Posted November 29, 2005 it's all done. perhaps i should have said - comes with no spare stopper tool to lock the old one before removing without having to pull the one from the new unit Quote Link to comment Share on other sites More sharing options...
beondwacko Posted November 30, 2005 Share Posted November 30, 2005 I ended up changing the CCT on mine ( thanks John01XX ) and I couldn't believe how easy it way. Just as it's been said before, don't pull the "pin" out of the new unit untill it's installed and torqued down. Don't over tighten it either. As for the old one , just un-bolt it , and toss it out. Clean the gasket surfaces with a clean razor blade and pop in the new one. Peice of cake. Quote Link to comment Share on other sites More sharing options...
