Tripple X Double X'er Posted July 10, 2005 Share Posted July 10, 2005 Ok I'm no mechanic... but I got up the courage to try cleaning out the carbs and jets on my bike. Most of my problems went away. The bike starts without hesitation and idles with no problem. The problem I'm having now is that there is a slight hesitation around 4 or 5,000 rpm. I don't want to do the carbs over, but if I have to I will. Any suggestions as to what my problem might be? Quote Link to comment Share on other sites More sharing options...
JB4XX Posted July 10, 2005 Share Posted July 10, 2005 check all your vacuum hoses. Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted July 10, 2005 Share Posted July 10, 2005 How slight? The carbed versions don't really hesitate as a norm, but they do have a flat spot in the torque curve that is nearer to 5500-6000 rpm. If you were running rich in the first place, that condition may not have been obvious at the time, but now is. Quote Link to comment Share on other sites More sharing options...
Tripple X Double X'er Posted July 10, 2005 Author Share Posted July 10, 2005 How do I lean it out??? Like I said I'm no mechanic. I wasn'r even going to mess with it until I started reading in this forum that it wasn't that hard to do. You guys are great! Quote Link to comment Share on other sites More sharing options...
86gn Posted July 11, 2005 Share Posted July 11, 2005 If your XX is otherwise stock you might be able to shim the needles. Quote Link to comment Share on other sites More sharing options...
