fasttraxx Posted May 31, 2005 Share Posted May 31, 2005 I've noticed hesitation when I roll into the throttle in 5th gear and 6th gear. Not sure if some carb cleaner will help clear this up. Any ideas? Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted May 31, 2005 Share Posted May 31, 2005 What RPM are you finding it does this at? Seafoam seems to be highly recommended for cleaning carbs. Can't hurt to try it. Quote Link to comment Share on other sites More sharing options...
fasttraxx Posted May 31, 2005 Author Share Posted May 31, 2005 between 4500-5000 Quote Link to comment Share on other sites More sharing options...
TechnoGecko Posted May 31, 2005 Share Posted May 31, 2005 Year bike, mileage? Has it been sitting? Some more info will make it easier to help diagnose. Quote Link to comment Share on other sites More sharing options...
fasttraxx Posted May 31, 2005 Author Share Posted May 31, 2005 I guess i should have put that in the first place...... 97' with 13,000 on her; not sure if she's been sitting too long, but I figure with those low miles she probably wasn't rode too much. Has a factory jet kit, but I don't notice any hesitation in any other gear except 5th and 6th. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted June 1, 2005 Share Posted June 1, 2005 I'm no expert but my guess is you don't notice it in the other gears. With the taller gears you'd notice it more. I'm sure it's just your carbs in need of cleaning if it's stat for more than a few months without fuel stablizer in it best bet is to pull the carbs and clean them up. Put it back together and balance them. There are some good posts on here on how to do both, just do a search. Quote Link to comment Share on other sites More sharing options...
fasttraxx Posted June 1, 2005 Author Share Posted June 1, 2005 I'm going with that then. Thank You for your help. Quote Link to comment Share on other sites More sharing options...
flipy351 Posted August 22, 2005 Share Posted August 22, 2005 Did you get rid of your hesitation in 5 and 6th gear if so how? Do you have the standard air filter in place or are you running a K&N or other after market free flow filter? I have noticed a similar problem running the K&N filter on my bird engine gets too much air and bogs under load at low revs in top gears. Standard air filter and jets runs no problems and no bog or hesitation. With free flow air filter Changed jets to 150 and motor has heaps more power and pulls hard up to rev limiter but still has bog under load at lower revs in upper gears. Not as bad as standard jetting but its still there. Was wondering if holes in slides need to be enlarged. I have also notice that when tuning motor without any air filter on when you rev it it will bog as if way too much air similar to running K&N filter. (Note need to hook up auxillary fuel supply to do this usually when syncing carbs.) Once standard air filter is applied all is fine again. Therefore my thinking is that the standard jetting is tuned for restricted air flow. Thus to run right it needs this restriction in the air supply. More free flow air needs more fuel richer jets and perhaps quicker operating slides by either bigger hole or weaker springs for slides. Any suggestion and comments welcome. Quote Link to comment Share on other sites More sharing options...
Red J Posted August 22, 2005 Share Posted August 22, 2005 Stock exhaust? Full system? Quote Link to comment Share on other sites More sharing options...
fasttraxx Posted August 22, 2005 Author Share Posted August 22, 2005 After cleaning the carbs, which I found to be pretty clean, I ran the bike again. Now I do have a K&N filter, so I'm going to assume that it is probably the same problem you are having. I will switch back to stock and see what happens. Thanks for the heads up on the filter info. That's something I probably wouldn't have thought about. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted August 23, 2005 Share Posted August 23, 2005 There's been a lot of questioning here lately with the K@N. Whether it flows more or actually less air. I'll never run one. Quote Link to comment Share on other sites More sharing options...
Obby Posted August 23, 2005 Share Posted August 23, 2005 My 2 cents... I have a '97 running a K&N Air Filter. The only problem I had with it was when I noticed that the choke started not working very well. I though it was the plugs or something, but it turned out to be the filter needing cleaning. After I cleaned it the choke worked fine and I had alot more noticable power. Quote Link to comment Share on other sites More sharing options...
