jc Posted April 22, 2005 Share Posted April 22, 2005 hi i'm new to the board, just had a few questions I'm thinking of buying a set of erion racing cams for the bird, and maybe shaving .020 off the head, anyone have any experience with this type of work, I want more power out of the bike without going to far, it already has a 4 into 1 exhaust and a jet kit. is .020 to much or could i go even further? I still want to run pump gas and it is a daily driver. any info would be appretiated Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted April 22, 2005 Share Posted April 22, 2005 I would check with Erion first. They should be able to tell you if there's any room to shave the head with their cams. Things are running tight in there from the factory already. Combining high lift cams with a shaved head might be trouble. Quote Link to comment Share on other sites More sharing options...
Northman Posted April 22, 2005 Share Posted April 22, 2005 You'll definitely want to measure valve/piston clearance, first, after installation of the cams before shaving the head. Unless, of course, you want to disassemble the rest of the engine :wink: Quote Link to comment Share on other sites More sharing options...
demon Posted April 22, 2005 Share Posted April 22, 2005 Erion has 2 different kinds of cams for the bird. One set is a drop in replacement with different valve opening duration. The other set is the higher lift with different duration. If you go the higher lift route, like northman said, be sure to check the clearances or you might smack a piston. Quote Link to comment Share on other sites More sharing options...
