erixx Posted April 6, 2005 Share Posted April 6, 2005 Hi all, just another R1 reg topic I found out that my second honda regulator is starting to show a melted plug (nearly 100.000 km done ), so time to change before it gets worse!! I read already all the onsite and elsewhere info, but haven't found any R1 regulator PART NUMBER (or Year) Yamaha dealer told me, they change over the years. Some question i found no answer for reading here: - Must the R1 regulator be for a Carb'ed R1? - Must it have a 6 pin (5 really) connector? - Do they come with instructions to match the cables? I would thank you very must if you could confirm this to me, as i need to buy the part tomorrow.... BTW, the Yammie part is 110 euro, the Honda 220 euro... they are joking! PD: I cut the honda regulator open, and W00W !! Theres nothing inside?? What the hell is the theory behind this device? :roll: Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted April 6, 2005 Share Posted April 6, 2005 Theres nothing inside?? What the hell is the theory behind this device? Ummm..........less to break? :? Quote Link to comment Share on other sites More sharing options...
bajjer9 Posted April 6, 2005 Share Posted April 6, 2005 just in case you havent seen this write up...I used one from a 00 if i recal correctly...installed it at 20k and its still running fine at 54k 1.5 years later http://www.vlc.com.au/~justin/about/bikes/...eg_replace.html Quote Link to comment Share on other sites More sharing options...
erixx Posted April 8, 2005 Author Share Posted April 8, 2005 Job done! Result good! Hardest part: match cables as 2 are different coloured. (i also bought the Yamaha conector) and solder the cables 'professionally' . PArt number: 3LD-82521-00 (R1 2000-1) Quote Link to comment Share on other sites More sharing options...
