Nev Posted February 13, 2005 Share Posted February 13, 2005 I have a new CCT to install. The manual says to make the key tool and use it to remove the old one. Do you need to do this if your installing a new one. I think I read on here not to take the key out of the new one before you install it. I could use that if you can remove it from the new one. Any advice. :?: Quote Link to comment Share on other sites More sharing options...
Redbird Posted February 13, 2005 Share Posted February 13, 2005 Don't bother. The way it was explained to me was that the only reason the manual says to rewind the existing one is for re-installation, which you ain't gonna do. Just pull the old one out, install new, remove key. Quote Link to comment Share on other sites More sharing options...
XX Posted February 13, 2005 Share Posted February 13, 2005 this device is sprung. the key, winds up a little thing that extends into the engine and locks in contracted. the manual suggests that you contract this thingy before de-installing. and contract the thingy of the new one before installing. then once installed, unwind the key to uncompress or extend the thingy. some folks have done this de-install / install without the key. if you got a key, yah might as well. clear as mud i know. btw, don't just pull the key out, the little thingy will unwind quickly and sometimes stick in an extended position. spoken from a true un-mechanic perpective :grin: :shock: :wink: ps they key is not the 'key' to uninstalling this device as it seems the manual is telling you. bolts holding it to the engine are. Quote Link to comment Share on other sites More sharing options...
Northman Posted February 13, 2005 Share Posted February 13, 2005 Don't bother.The way it was explained to me was that the only reason the manual says to rewind the existing one is for re-installation, which you ain't gonna do. Just pull the old one out, install new, remove key. Go with Redbird's advice, and try your best to ignore XX's :shock: Quote Link to comment Share on other sites More sharing options...
Nev Posted February 14, 2005 Author Share Posted February 14, 2005 Thanks - I figured you didn"t need to wind it to take it off but I wanted to be sure. Mine's not too noisy yet as the bikes only got 16k on it but I thought I'd change it while I had the bodywork off for some maintainence work. Quote Link to comment Share on other sites More sharing options...
