CBR-RR-XX-CESS Posted February 7, 2005 Share Posted February 7, 2005 http://www.activeboard.com/forum.spark?for...bForumID=105421 Quote Link to comment Share on other sites More sharing options...
HERBXX Posted February 8, 2005 Share Posted February 8, 2005 BTW here are the shim stacks from a stock xx shock documented, and the stacks im using in the 600 shock im built ofr my xx http://www.activeboard.com/forum.spark?for...1076&topicPage= Quote Link to comment Share on other sites More sharing options...
Byrdman Posted February 8, 2005 Share Posted February 8, 2005 So Herb, You only made three slight changes to the shim stack? I have an extra XX rear shock as well, I might perform the same surgery as you did. Quote Link to comment Share on other sites More sharing options...
HERBXX Posted February 8, 2005 Share Posted February 8, 2005 I figure i added 10 or 15 percent to the rebound for the heavier 1100lb spring , took a liitle off the compression.( i can add a bit more with the adjuster) Remember i rebuilt the stack inside a the f4i shock !!! I used silkolene rsf 7.5 oil.( equals showa 10 or ss 8) I didn't want to change the stack too much as changing the oil and to the f4 shock with the compression adjuster will have some effect. Once i ride it i will most likely make more adjustements. I also lapped the piston faces to promote sealing. As far as i can tell the piston in the f4 shock and xx is the same . So if you got an f4 shock and some thick shims you could leave your xx shock alone . The f4 shock is 1/2 inch shorter than the xx shock. You need to make a top perch so you can use standard 2.25 X 6 springs (see my pics in other posts) Herb my old post with pics http://cbr.geckobox.net/forum/viewtopic.ph...6625&highlight= Quote Link to comment Share on other sites More sharing options...
