HERBXX Posted November 15, 2004 Share Posted November 15, 2004 Have been able to drill resevoir , disassemble , reassemble , install fill valve, test to 200 psi , no leaks. I think the xx spring will fit with a lot of thought and a little lathe work , still trying to figure out how to build a preload adjuster. I need a real compact preload adjustment system.. and more f4i shocks in case i wreck this one before im done . Herb Quote Link to comment Share on other sites More sharing options...
