HERBXX Posted September 13, 2004 Share Posted September 13, 2004 I just filled up with gas , put the key in the ignition and it jammed, refusing to turn . Had a buddy bring my spare key , same thing. I played with it for 15 minutes and it finally turned. I put some contact clear in the key hole then some fancy spray gun lubricant by dad had and it seems to work better then ever now. So if you haven't lubed your lock lately you may want to !!! BTW look at you manual this thing would be so simple to hot wire. That is my backup plan if it ever happens again far from home Herb Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted September 13, 2004 Share Posted September 13, 2004 Never spray oil into key holes :roll: go get you some graphite and use that. Oil will let dust and grime stick to it and can cause more problems than its worth. :wink: Quote Link to comment Share on other sites More sharing options...
HERBXX Posted September 13, 2004 Author Share Posted September 13, 2004 The stuff i used goes dry , so i hope i will be okay, though i guess i could wash it out with contact cleaner and get some graphite. Quote Link to comment Share on other sites More sharing options...
