Dion Posted July 2, 2004 Share Posted July 2, 2004 I'm off work Monday and it's suppose to rain so I figure it'll be a good day to work on the bike. Planning on plugs, air filter, oil/filter(already) and lube/adjust throttle cable, sync start valves. Does anyone have any suggestions for other things on an FI while I'm into it Quote Link to comment Share on other sites More sharing options...
Guest Posted July 2, 2004 Share Posted July 2, 2004 Rotate the blinker fluid. Night and day difference! BTW - what is this rain you speak of?? Quote Link to comment Share on other sites More sharing options...
Dion Posted July 2, 2004 Author Share Posted July 2, 2004 Rotate the blinker fluid. Night and day difference!BTW - what is this rain you speak of?? No need, I've already converted them to pneumatics. This way I never have to bleed the blinkers again. Re: the other question. Turn west and start walking. You just keep walking until it feels like you've wet yourself. this is called the ocean. It's filled with water. Now rain is little bits of this water stuff and it actually falls from the sky. This is how the ocean gets filled, well, flushing your toilet helps too. Sometimes this rain can cause you not to want ride your bike, I know, this is a bad thing but at least it tends to keep the trees from burning. :razz: Quote Link to comment Share on other sites More sharing options...
Dion Posted July 2, 2004 Author Share Posted July 2, 2004 sync the start valves......???Is this a buddhist thing? No, it's a motor thing. Same concept as syncing the carbs Check the manual 5-83 Quote Link to comment Share on other sites More sharing options...
RodeRash Posted July 2, 2004 Share Posted July 2, 2004 I've already converted them to pneumatics. This way I never have to bleed the blinkers again. Quote Link to comment Share on other sites More sharing options...
