Everything posted by greysnail
Hi guys,wrecked my bike a few mths back,estimated repair cost will be ard $3k so opting for a streetfighter project.Gonna fix a dual projector headlite for the front.But the main question is is there anyway i can drill the top yoke to fasten a handle clamp for Renthal bars as i wont look gd if i use the clips.I've search under LSL handlebars and its almost similar except i'm drilling the yoke as i can get the handle clamp for a fraction of the price.Will it be strong enough to take the stress steering this beast???
I really envy you man,really wish i have the intelligence and time and place to do wat you are doing.For now,i can juz simply watch and wait for the finale.Gd job Stan.
Check all wirings,fuses and connectors. Strip the whole fairng if u need to.
Where do you find this? in Singapore.. SIngapore???.......dat where i'm at....
Check for any loose connection on the grounding area.Not to forget check the ECM unit whether any frayed pins.
U dun have to turn it on,if it drips,then ur FPR is busted. Do take note while removing the FPR,there's a spacer attached to it.Reuse it with the new FPR. Once fixed,ride away and blast off,u'll be surprise to see the accumulated fuel in ur endcans.
Fuel pressure regulator????
My bike had its 1st electrical glitches after i've changed the coil,rectifier and battery.Mine a 01 Fi model.2 days ago,during warming up,my neutral starts to intermittently blink during idle,suddenly all lights were up and then dead.Upon inspection,found my magnetic starter assembly which is house the main fuse(30A) got toast really bad.Managed to get spares from the dealer at $48/-.Fixed it and go. Now my question why is dat so?Is there an overload somewhere?I checked the 2 wires connected to it 1 goes to the starter and the other goes to the battery +ve.
+1 If the clutch doesn't slip while on the gas, it sure as hell ain't slipping when you're decelerating unless you're not letting the clutch lever all the way out. ya thats it..false neutral. Will it harm my engine????
Hit the track for the 1st time and man,this bird could handle corner very well along with gd tyres-Pirelli Diablo Corsa.Hot weather making the tyres stick to the road with ease......but when trying to drop gears after a long straight,my clutch slipped,making my bike powerless till it reached a certain speed,then it engage.Been a couple of times it happen.Clutch plates recently changed,oil is 15/50w(semi).Mebbe i didn't kick down the gears hard enuff,i dun noe,adrenaline rush upon reaching those corners mebbe setting my balls up my throat.Is there any other contributing factors which lead to this? Oil due???
Definately a great website to surf....either machanically,electrically oh yeah....and the NWS too....hehehehehehe
Another question.....y is it so??
Hmmm...tot of modding the collector and getting rid of the left connector but vehicle inspection here is very strict and of cos wat i'm doing now is illegal but who cares.s long i'm able to fit my 2 ori pipes for vehicle inspection,i'm good.
So u juz fixed a stopper on the left and thats it?
If dats ok,i'm gonna get myself an Akra endcan meant for GSXR.I'm juz worry abt the backflow issue.Bikeshop in S'pore doesn't bring in Yoshi full sys anymore...
Hey guys,juz wanna noe if its possible using the original manifold/collector for a single endcan.Do i need to modify the collector? Any inputs is appreciated.
Wet connectors???Well i see some connectors are wet with oil especially those near the engine bay.Not sure whether its the cause. Mine is a 2001 Fi digital dash by the way Wet as in "weather". Corrosion and such, in the switches contacts, and the wire loom connectors. But they should be sealed enough. Why is there oil? Oily connectors can conduct electricity, the wrong way. May have to put a new knock sensor. Hmmm,wet with oil...mebbe i'll clean-em up and see whether thats the cause..til then,wait for the result.Wondering where the oil come from...mystery....
Thnx for the thread/link guys,done everything as above but still the same.
I've unplugged the ECM,check the KS but the problem still exist. If i were to swap the ECM,would there be any issue with the HISS? If no problem,then i'm willing to spend on a new ECM as i've chaged the main harness.
Hi all,been browsing the forum for quite sometime now and this is my 1st post. My bike is a 01 Fi model,been having great fun with it til the Fi light came put which reads 25 blinks-knock sensor. I have the manual and i've recently changed the main harness.I took a look at the loom on my old harness and its clean as a whistle.But my bike's Fi lite will stay on along the journey.Once i hit 3k on the RPM,the Fi lite will appear and will remain ON til the end of the journey.My mech says my ECU a goner..is it true.And yes the performance drop once the Fi appears. Any kind soul to help me out.....Oh yeah...saying Hi from Singapore.
