chasg
Everything posted by chasg
  1. I am using Jaws bar risers,vtec bars and light switch with existing cables.
  2. l have a problem with my front brakes. The free play in the master cyclinder lever is continually changing when riding. Some times the lever has the correct free play then there is very little free play. I have replaced the complete front brake assembly( master cyclinder,brake calipers,brake pads and lines of another bird) to identify the problem without success. I have filled the brake fluid level to just above the minimum level to prevent any pressure buildup in the master cyclinder. The brakes have been vacuum bled. Also the front brake make a buzzing noise when applied. This l believe is caused by air being trapped between the pads and the disks. Any ideas? The only parts l have not swapped over is the front wheel and discs.
  3. chasg
    frame sliders
    Here's a couple of photos showing installation points.
  4. Here's another HID light comparison pic on low beam.
