Thanks CxBXR, T REXX14, cbrzxxx for helping . I found the problem
First I took the radiator, oil cooler off. Then I removed the valve cover to check if the valves got stuck. All buckets moved up and down.
Then I rechecked the compressure. After 5 stroke they all came to 150PSI 9th stroke they came up to 170PSI.
WTF I wondered. (I have the leakdown tester but no adaptor for the new compressure). So I started looking at all vacuum hoses as cbrzxxx recommended. The fuel pressure regulator vacuum line is connected to ONLY 2 cyl 2 + 3 not like cars to the intake manifold ! Without thinking I removed the vacuum line @ fuel p/r . A F.. drop of f..ing fuel dropped out. Without hessitating I sucked in the pressure regulator. THat taste of gas makes my day!!!!
So the fuel cleaner destroyed the fuel pressure regulator !!!
Thanks guys :icon_clap: :icon_clap: :icon_clap:
