afd44
Everything posted by afd44
  1. Be very careful of those filtrete and pleated filters as they can raise the static pressure in your system and cause problems especially in cooling season. I do HVAC for a living and our factory rep says not to use them at all, but if you must, change them VERY frequently. Later Lonnie
  2. afd44
    Freeking Furnaces?
    Shouldn't be much playing around they should have given you directions, i.e. which color goes where to do what. it's not a big deal but until you get it slowed down you are gonna experience this problem, It could cause other problem's down the line. Later, Lonnie
  3. afd44
    Freeking Furnaces?
    Carlos is right it is called a "fan limit switch" it senses the air teperature coming off the heat exchanger, if you installed a larger or more powerful blower motor it is cooling the heat exchanger off too much and therefore the limit switch will shut it down until the temperature comes back up to where it needs to be and then will allow it to come back on. I would say that you have too much blower speed!!!!! also as Carlos said depending on the motor that was installed there should be a way to slow down the fan by changing the wires, most of the blower motors that are installed these days are what is called a "multi-tap motor" you can change speed or even voltage depending on which way it is wired. I am not an expert because I have only been in the HVAC business for 10 years :oops: But I would say that is what your problem is. Hope this helps, Later Lonnie
