kimbrian01
Everything posted by kimbrian01
  1. Checked pad pens which seem to be fine. Working/testing bike on center stand on lift. I unhooked the line going from rear master cyl to front of bike. Used the master cyl with just the rear caliper and wheel spins free. When I activate only the secondary master cyl, the rear spins free. So when the whole system is hooked back together the wheel drags. This leads me to believe there is a problem with the time delay valve. I purchased a used delay valve and put it on. Same problem. Then took the delay valve off other bike and put on this one. Same problem. My next step is to get the other bike back together to be sure it is still working properly. I use a vacuum bleeder along with the conventional bleeding method as instructed in the maintenance manual. I've replaced the rubber hoses but have not yet addressed the hard lines. By the way, both bikes were working fine and no previous issues. One bike is mine, one is my wife's. We can't pin point the start of the issue. Changed the tire (yes, did inspect everything w/the wheel to be sure that wasn't the problem) then rode about 700 more miles over 3 days in serious curvy roads using the back and front brakes fairly hard. Then got home on the straight roads and rode about 100 miles. When oiling the chain, could hear metal on metal. Discovered that the brake pads had been worn to the metal. I assume it was the last day that we rode the 100 miles that the problem started but cannot be sure. Thanks for your input. Any more ideas are welcome. In the next couple of days, I hope to get more chances to work on it.
  2. Thanks, but not the problem. Had swapped the caliper from the bike working perfectly fine to the one that's not. Still have the problem. Thanks, but did check that. It seems to be fine.
  3. Need help. Have done everything I can think of to correct problem. The rear brake drags for about 2 seconds after the rear pedal is released then spins free. If I depress and release the rear brake pedal, wait 2 seconds, then the wheel spins like it should. The wheel should spin freely immediately after releasing the pedal. I have two 2003 black birds. After rebuilding the rear caliper and master cylinder and bleeding the whole system still had the problem. Then began taking parts from the second black bird which all the parts worked perfectly on. I swapped the rear brake caliper and mount, hose, rear master. Still have the problem. Then I swapped time delay valve and secondary rear master cylinder and the pcv. Still have the problem (Yes, I did the bleeding each time with a vacuum bleeder). If any one has any ideas, please post. I am a Daytona Beach AMI graduate and completely stumped at the moment.
