Everything posted by JaBr
Headstock bearings were completely knackered, there wre a couple of notchy bits on the sweep and a deep notch dead ahead
Stator is toast, and connector is crunchy So the plan is to buy a higher capacity stator and a mosfet reg/rec. Fun ๐
Well luckily now the stand is up and the bike is on it I have a little more space I'll have more photo's later, currently rad is off and stator cover.
So here it is at last, built up and almost ready for use. This is how little space I have to work with Just for fun, what's this under the cover? And what's it off?
The big reveal will happen later today
Well to be fair, we are quite obviously correct ๐คฃ๐ The legislation is BS7671: 18th edition, it's a monster of a book, there is a 2 hour exam on it that you have to take, open book but still tricky.
Stumbled across this today, much cheaper than anywhere else I've seen them.
That makes sense then, we had a few colours available for the full production run, I believe the titanium is one of the rarer colours.
I am seriously considering the steering head bearings, a little wary of them but why not, I'm doing a bunch of other work I've never attempted before. What's the worst that can happen ๐ When you say Ti do you mean injection or are you referring to the colour? There are 64000 miles on her, sadly she's been a bit neglected in the past and I'm picking up the slack. Seems to be a bit of a theme with me, I currently own 3 cars that had similar neglect issues. I'm very pleased with the seat to be fair Not complete laps sadly, some of the roads have low (30mph-50mph) speed limits on because they're either in built up areas or considered a safety risk for us mere mortals. The mountain is unrestricted, and so is the Cronk-y-voddy straight so you can easily hit silly speeds along there. Also, outside of TT fortnight the roads are all 2-way as well, during the TT fortnight the mountain is one-way, you see some quick riders up there then, I'm sure some of the racers go up there to practice on road bikes.
The UK regs are very clear on this, in fact, you can be prosecuted if you provide the earth from the main building, if a building is detached from the building that supplies the source of power it must have it's own earth (Ground), this is usually delivered by installing an earth spike. I don't know about US/Canada as they don't use proper plugs out there, it's weird round ones ๐
It's by a guy from the UK, Alistair else, company is Else Made. He's a really nice guy and his work is excellent, he's also done my VFR seat. Both covers have been custom made, and had dual gel pads fitted as I regularly carry a pillion. The blackbird seat was ยฃ340, the VFR ยฃ320, ยฃ50 for shipping. I also provided him with my spare seats.
The things we do for love ๐
So you know that one little job that always seems to lead to another little job... I've had some disks and pads, rear brake light switch, camera's and posh reservoir covers lying around for a while, lockdown seemed like a great time to sort the work out. Here's what's happened so far. I proceeded to remove the rear caliper and get the new pads on, the disk is ok so I'm leaving that. For some reason the pistons on the caliper don't want to move, hmmm, maybe get a seal kit, hold on to that thought. Now I move to the front, have disks and pads at the ready, what's that shiny stuff on the calliper Ah yes, that would be brake fluid, leaking on one of the banjo's, hmmm, calipers off, again, more seized pistons. Right, easy fix or expensive fix, expensive it is then. All hail Hel and their beautiful braided lines kit for linked braking, oooh, shiny New stainless steel pistons and full seal kits for the calipers too, ouch my wallet. Parts ordered, not yet fitted. While I'm at the front I notice surface rust and fork oil on the stanchions, fork seals, bushings, and new oil then. This list is getting longer. Panels off, a couple have seized bolts and they have to be drilled out, new set of shiny stainless fairing bolts then, oh and some stainless driver bits to avoid rust transfer from standard steel tools, thank you Wera. Tank off, air filter and spark plugs, NGK Iridium, a bit tight getting them in but ok, all done. Oil and filter change to come later. Hmmm, radiator looks a bit iffy, the inserts are crumbling, new radiator and an R&G guard on the list. Seeing as everythingโs going to be off, might as well do the wheel bearings too. Today, the reupholstered seat has arrived, put that to one side ready for when it's all completed. Abba skylift due Thursday. So the list so far... 1. Front Brake disks and pads 2. Rear brake pads 3. Service - Air filter, plugs, oil and filter change 4. Wheel bearings front and rear 5. Fork seals and bushings, fork oil, repaint uprights 6. Braided brake lines 7. Posh reservoir covers 8. LED dash lights 9. Switched secondary fuse box for accessory circuits 10. Thicker stator wire 11. Standard chain guard to replace current damaged hugger 12. Radiator and Guard 13. Subframe, calliper mounts, and upper cowl stay in for shot blast and powder coating. If the original subframe survives the blasting I'll have an injection subframe for sale that's like new. 14. Deep clean while everything is off 15. Chain and sprockets 16. Reupholstered seat to be fitted Still, at least when this is all done I'll be able to get it tested and registered here in the Isle of Man at last, still on UK plates at the minute.
Excuse my ignorance, other than the price, what is the advantage over a standard CCT please? Mine is a '97 Carbie, I know the standard ones are fairly weak and I've been eyeing up the Jaws uprated version.
