BearXX
Everything posted by BearXX
  1. Nope. He's still here. I still think it is Dave or one of his hemorrhoids ... If not, he was stupid enough to answer... :icon_silenced:
  2. wow so bad ass on the net huh? im in phx too buddy let me know what you wanna do or is this Dave with another of his fucked up personalities...
  3. +1 Fitted both bikes today with the HID kit, and what a difference :icon_thumbsup: $80 to Norway shipped and taxes. 1/2 price of what the sell in the stores.
  4. Yellow :icon_shocked: It's a big road construction vehicle...
  5. This one came today. Looks ok.
  6. Runner, you'll hv no regrets... :icon_thumbsup: I've been doing other things at the same time so I have quite a bit apart... but I think at minimum, the windscreen and dash. I didn't remove the dash completely, just removed the mounting nuts and moved (w/harness still connected) towards the triple to get it out of the way. I also re-routed the large harness that you see in the picture away from the where the ballast was installed and moved it going through the center of the stay. If you use that spot for a ballast, one of the windscreen bolts will be very close to the corner so just be aware of that closeness when doing your final securing. Also, it'll be even trickier if mounting two ballasts under there. :icon_shifty: It can be done though, just trickier. I'll only use one set on each bike
  7. Got it, will send it out on Monday or Tuesday to you... this is where I installed the ballast fyi. So the easiest way is to remove the windscreen? or do I have to take of the front?
  8. I ordered this http://cgi.ebay.com/ebaymotors/_Car-Truck-...p3756.m14.l1318 H7 HID 4300K
  9. Bjorn, The H7 is a single filament, 1 bulb/ballast will replace with upper light, low beam. I kept the high beam bulb non-HID because I switch it on and off with traffic frequently enough that if it was HID, it wouldn't be very effective. As the HID bulb needs a few minutes to full brightness after switching on. But if I was doing desert run's at 3am a lot, then HID high beam would be very effective too. OK. We're so far north that from mid of may to mid august it doesn’t get totally dark. It will be great to have in the fall. This set should cover both bikes.
  10. I ordered a set. But this is an area I'm green. Does this H7 4300K work with low and high beam? :icon_think: You posted only low beam.
  11. Will this dude stop before the XX? Same weight as an "Fat Boy"
  12. Do you have this in store? I'm not allowed to shop at Ron Ayers. International shipping is not available. http://www.ronayers.com/BrowseParts.cfm?pr...d=16953-ML0-024
  13. Petcock diaphragm fucked
  14. I had the same problem when changing the front sprocket. The old had rubber dampening while the new one didn't.
  15. BearXX
    Increase HP
    Someone who doesn't know the difference ? :icon_think: HONDA CBR 1100XX CB 1300 S BLACKBIRD
  16. It has about 31 000 miles on it. Some small scratches is on the front fender but it's a 11 year old bike. How much for it ? I'm still waiting an answer from the previous owner. That's the one. Price is up to you, must at least cover shipping, as far as the lil square that goes under the head light I can get you one OEM at cost. I don't like to ask parts for free. $30 for the centerstand and what the square that goes under the head light would cost + shipping.
  17. How much for it ? I'm still waiting an answer from the previous owner. That's the one.
  18. We picked up the bike yesterday and a couple if items are missing. The centerstand is gone, and the lid underneath the bulb is gone. I'll try to reach the previous owner, but if he tossed it, I need another. 1997 Blackbird.
  19. NO FUCKING WAY!!! its 11. I need to put something on my hair.. No, really, you look 40 Tom. Don't move south... The cold slows down aging.. Nice bike
  20. 30 000 miles 97 mod Maintenance: 1 set brake pads front & back 1 set chain w/ sprockets Battery gone after 5 years 3 push pins Many tires Failed: R/R (My fault) Petcock diaphragm Tool kit rubber band gone 2500 miles 06 mod Nothing..
  21. The older bikes R/R is without cooling fins. They upgraded to cooling fins on later bikes. R/R has always been a Honda problem
  22. :icon_popcorn:
  23. A very small hole. The tire gets warm and he wheel is turning it expands and lets the air out. Pump it up to 50 psi and check it again. :icon_think:
  24. The spring on top of this one, and mount it. Found this thread, and it helped me. http://www.cbr1100xx.org/forums/index.php?...&hl=petcock
