I've had the bike for 2 years. It had been crashed and the right side was pretty well wiped off. Left side except the mirror was fine. Got a deal on stock pipes and restored the rest. Fuel had been left in bike too long and I had to clean carbs, fuel lines, tank. I've run Sea Foam thru it, and replaced the plugs afterward. Tell me more about enrichment circuit.
After it starts, it runs great! Restarts fine all day. Unable to locate idle mixture screws on bottom of carbs. Only adjustment I see is in between #2 & #3 carbs and it's the throttle cable adjustment.
Thanks
the enrichment circuit is mistakenly called the "choke" but works opposite of a choke... a choke blocks off air and leaves fuel unchanged, but an enrichment circuit, like the 'bird has, just adds fuel at idle when the "choke" lever is pulled... These are very small ports, and are very easy to plug up when the bike is sitting, and are also pretty hard to get clean...
So, what exactly does it do when starting it? how do you get it started, exactly, when it's cold?
Mike
It acts like it's flooding. Sometimes a small shot of ether will get it to start, but I don't like to use it
. It also sounds like only 2 cylinders are firing #2 and then it dies. If you give it a little gas it also kills it. I usually set the idle up and like I said it sounds like 2 cylinders running until it warms up a little then give it throttle and it will kick. Flash
