nobbyjeff
0 Neutral
  1. I am currently experiencing a similar problem with the front end of my Bird while accelerating to 60 kph after that all good. I replaced wheel bearings, fitted tapered sterring head bearings, changed fork oil, did a wheel alignment and it was still there. This was driving me nuts as I have never had a problem with wobble. Then i rememberd i had punctured the front tyre the day after it was fitted (couple of months ago) and due to circumstances it was tied down in the back of the ute for a day. I had the tyre repaired and thats when the wobble problem started. After I had done the above trouble shooting work I quized the local bike shop as to whether the repair and /or being tied down for a day may have damaged the shape of the tyre turns out there is a slight deformation in the tyre causing my problem, will fit a new one in a week or so and see if that solves the problem. I have pretty much always run dunlop tyres but have tried others at various times, Bridgestone, Michelin but have always gone back to Dunlop. I found the 220 very good for about 3000 ks then the front would chop out, still had heaps of rubber but felt choppy in corners. The 207 was very sticky handled well but was all but gone in one good hard ride (too soft). I currently run 205s and am very happy with them (above problem exempted), very predictable, completely stable, good in the wet and good mileage, usually about 8,000ks. Anyway thats my two bobs worth, ride safe.
  2. nobbyjeff
    Dynojet
    I have a 98 bird as well and have done the stage 1 dynojet kit, have K&N filter as well. In my opinion it's worth doing but I would highly recomend it is done in conjunction with Dyno tune, it gets the jetting exactly right, tailor made to the bike. When mine was done I didn't have to use all the bits that came with the kit, ironed out the flat spot and gave me a good flat power curve, the before and after print out from the dyno was amazing, didn't really gain any more power (135 hp at back wheel) but it pulls like a 15 year old. The only and slight downside is the power delivery is a little brutal (and addictive) from low speeds. I can't remember how much I paid for the kit but it cost me about $300.00 aus to get it fitted and tuned. I can if prudent still get 300ks to a tank (doesn't happen very often) usually average 250ks but if you get up it, it can drop to under 200 ks a tank
  3. nobbyjeff
    dash swap
    Does anyone know if it is possible to fit a latter model digital dash to a 98 bb, look the same shape externally, any pros/ cons. Ta
