Weiner127
Everything posted by Weiner127
  1. For some reason I can't open that PDF file. I'll post more info after work Thanks for the replies
  2. It appears that the starter relay maybe is toast now. I'm not sure how it was working at all with the totally melted fuse, must've spanned the connection but now when the key is turned on there is no power flowing out to the 2 rear wires. Must be an electrical guru out there somewhere Thanks
  3. My 98 wasn't charging so I was troubleshooting and came across a totally melted fuse on the side of the battery box where the connector goes. I assume it's the main fuse. I pulled out the peices and installed the spare 30a fuse now nothing. The clock works but as soon as I turn on the key it goes out. Nothing else, no lights, horn etc. The ignition fuse is fine. There's power at the fuse and power at the 2 rear poles where the connector goes on. I'm downloading the manual now but thought some experienced guys may have a suggestion. Thanks
  4. Well, I cleaned things up (they were'nt dirty), sync'd the carbs (they were real close anyway), checked the petcock diaphram (OK), set the pilot screws 2 turns out. Had to order the 45 pilots I want (be in end of week) Unfortunately the weather is crappy here, calling for snow and freezing rain and below feezing temps for the next few days so I can't take it for a rip I'm still open to specific carb set-up specifications if anyone has a good working one
  5. Hi I have a 97 CBR1100XX. I got it with a Muzzy pipe and a Dynojet ket kit. The bike works real bad at cruising speed. Not just a flat spot or slight hesitation like I read about. Whack it a 4000 and it just sputters and backfires, pulls fine up top though. Anyway I tore into it tonight thinking maybe the jet kit was out of whack or installed incorrectly. It has the stock stage 1 kit installed correctly, stock airbox, KN filter, 140 mains, slide drilled, clips 3 down, 42 pilots and the air screws 3 turns out. From what i've read this combo should work good. I'm at a bit of a loss here so any specific set up info would be greatly appreciated, i can't seem to find specifics doing searches. It's a bitch to take it apart so I'd like to try to hit on a good combo right away. Thanks for any help
