leftcliq
0 Neutral
  1. Hi Guys, I recently bought the Euro RH switch as well. I'm wondering if the socket on the end of the cable will plug directly into the connector block or is there some wiring that I will need to do? I'm riding a '97. Thanks, Dale.
  2. Hi again, Could the problem be that when you use the choke to start the bike, its fowling the plugs with all of the unburnt fuel? I suppose the only way to check is to inspect the plugs and see what they look like. Regards, Dale.
  3. Hi, I have a similar problem with my '97 carbed XX. Although mine splutters at about 150kms and during hard acceleration. I know the carbs have been re-jetted. Could this be that the bike is running to rich causing the carbies to flood? Or could the carbies be running to lean? Would a K&N air filter help or resolve this issue? Also, I don't have very good fuel economy. I get about 250k's out of a tank of fuel. Any advice would be appreciated. Dale.
  4. Hi, Is the light directly hardwired to the ignition or is there a relay hiding somewhere that I can check? -Dale.
  5. I'm actually in Australia. The switch is designed to either have both lights working or just the high beam light when you turn the high beam switch on. Does your bird have this? -Dale.
  6. I'm actually in Australia. The switch is designed to either have both lights working or just the high beam light when you turn the high beam switch on. Does your bird have this? -Dale.
  7. Hi Guys, I just wanted to add that at the bulb I get 11.1Volts and the battery has 12.6Volts. Thanks, Dale.
  8. Hi People, I have a minor dilemma, my front main light ins't working. Before you ask, I have replaced the bulb and still no light. Its a 97 XX. The light comes on when you have the dimmer switch on and I turn on the high beam. Does anybody have any ideas? Or does anyone have a wiring diagram for the 97 XX? Thanks in advance, Dale.
