Ok - here goes.
My house has full finished basement, but there is a crawl space under the floor and sump below that. Not easy to get to. In my front yard along the property line is gravel bed, and there is a black PVC line there that keeps bowing up and un-buying itself. Looks like crap. It apparently goes up to the side of the house then into the crawl space to the sump. Twice in the three years I've lived here I've taken a pick and shovel, dug a trench under the line and reburied it best I can - but I guess with temperature changes etc it just pushes its way back up.
On the other side of my property my neighbor has the same setup. Except that 1-2x a day his drain pumps out a good bit of water - probably a half gallon or so a couple times a day. His is the only house in the neighborhood that seems to pump water at all. Still - I was concerned that our houses were that close together and he has all this water in his sump and mine isnt pumping.
So I pulled up the little catch in the basement floor and crawled my fat ass over to the sump. To ad insult to injury someone ran the main sewer line right over the lid on the sump. Took me a minute to weasel the lid off and look down. There is a pump there covered in dust, and zero evidence the sump has ever been wet. Some heavy, dry dust in the bottom - no water line or any sign of water ever. I get the lid put back on and while I"m there look around a bit - and I notice that the drain from the sump pump to my drain outside isnt even connected - and as far as I can tell never has been in the 20 years the house has stood. The line from the sump and the line from outdoors kind of end in the same area but arent lined up and actually way overlap in length. Looks like it was half ass put in and never connected.
So my real question is - should I either figure it out and connect the line like it was supposed to be - or more to my liking just cut and cap the line outside so it doesnt keep sticking up out of the ground. Just eliminate it entirely. Do I even need it??
A third alternative I guess is there is a deck drain in the area from the sump - it's connected to the basin under the water heater, I suppose to let water drain off if the heater leaks. Its a smaller diameter but I could probably tie the sump pump line into that drain without a too much fuss.
Any thoughts? Never had a house with sump before.
