Posts posted by RXX
13 minutes ago, XXitanium said:
Did you se the CL add?
Yes. Jackson would be cclose to 8 hour round trip. I have BBS. Plus, they are round.
1 hour ago, XXitanium said:
I try to run only non-ethenol gas in my bikes.
I keep a couple bottles of Stabil around also.
Same here except for the Stabil
Thanks for the help guys.
8 hours ago, XXitanium said:Why a month? A month shouldn't hurt it.
My bikes sit over winter with no problems. Are you considering Por-15 at all?
7 hours ago, superhawk996 said:Or anything because it's only a month.
Well, by a month, I guess I mean up to 4 or 6. I get sidetracked easily and often. And yes, I thought about coating the inside, but jesus on a cracker, 85,000 miles, 20 years old, bike worth maybe $1200, why? I won’t be riding in 10 years. But tell me your experiences. I did it to a sportster about 30 years ago and do not remember anything about it.
4 hours ago, XXBirdSlapper said:XX tank? Was it rusty? If you etched it to remove rust add a little premix and slosh it around. Even without being full the vapors will protect it. Skip using ethanol and use pure gas.
Yes, on my ‘99. It had an awful lot of what I assume is varnish. I have the fuel pump off, and can reach in there. I got a big speaker magnet in there and it did come out coated with rust, so I assume the shit left inside is the remains of all the negative karma that has flowed from me while riding to be bottled up there. Maybe I should leave it there, like Dorian Gray’s portrait.
I vacuumed it out and am going to put a couple pounds of BBs in it to break up the rest.
I am working on my tank right now. By right now I mean for the last few months. The interior had a bunch of shit in it that I have pretty much cleaned out. Thing is, it will prolly be at least a month before I get it installed and filled up.
Is there something innocuous and cheap I can coat the inside with to keep it patent? WD-40? Mineral oil? Thin motor oil?
On 4/18/2019 at 8:53 PM, XXitanium said:
So, the kid stuffed his XX out in the back shed at gramma's last fall. His Mom heard of a natural cure for rodent infestation.
Makes sense. There are no snakes in Ireland, so prolly no rodents either.
On 4/16/2019 at 9:01 PM, SwampNut said:
Learning to deal with temptation is a good process to go through.
Duh. It is a good process simply because dealing with temptations is just life. There are multiple ways of dealing with any specific temptation, and we are bombareded with temptations from the moment we wake until we take our dirt naps. We cannot ge5 away from temptations. Breathing, not a temptation. Pissing or not...... temptation.
Temptation equals choices, and fuck I have problems with the whole “choice v. choices” deal.
May be a hijack, but I installed a Stebel Nautilus http://www.stebel.it/stebel/products.asp?IDserie=14&uso=1&tipologia=moto on my bird and used existing horn switch. Installation requires a relay, but otherwise pretty straight forward. It is the primary horn, the OEM is now a paperweight somewhere.
I’ve been wondering where you have been. I have seen your bike, that is a great price!
1 hour ago, DBLXX said:
You so sure about that? LOL
Yep.
6 hours ago, Zero Knievel said:
That's one expensive adult toy.
Cheaper than a broke neck.
$325.00
2 years old, stored in box. I have used it for a total of <2 miles. I had a panic attack using it. It will not go on me again.
Bummer. In dim light, the thread title looked like “gas filler porn”
Ping Zero. I have. a PC3 on my 99. Got it from him, and it came with a computer. I am reasonably sure that is what is on it.
Huh, the filter that came out was the straight one. I KNOW it is original since I bought the bike at 2700 miles. Already bought the crooked one. Prolly the last one I'll get for the this iteration.
OK, KNOW may be a stretch, but pretty damned sure.
20 minutes ago, redxxrdr said:
XX?
if so, I would change the filter while there. I the filter has a 180 degree fuel line on one end, then there is a cheap replacement at your flaps. If metal 180, a replacement was $50.00 a couple year back
Way ahead of you there, buddy. Have one in my cart right now. $55 and shipping. About to order the assembly gasket also. Like I said, it is not rust, and easy to clean out. Air gun and BB’s ought to do the trick.
Might use Slappy’s warm milk recipe just in case.
Well, never mind. After taking the fuel pump off, what I found was a crust of varnish or something that flew right off when hit with a high-pressure hose.
I just drained a couple year-old tank of gas out of my bike and there is some rust patina inside. Both are too expensive to buy 6 gallons to fill the tank. Is one demonstrably better than the other?
On 2/5/2019 at 9:02 PM, redxxrdr said:
I looked at many of the suggested battery’s.
I finally chose a scorpion.
Mid range price (for these batteries), equalizer circuits, to balance the cells, and no specific charger required.
But you are correct. When you pick it up, you are sure that you have been ripped off.
So light. And the XX spins real fast.
Time will tell how long it last.
I missed a early retirement package by being 11 days too young. So I guess that I will be testing the shelf life function this year.
Craig, what model is it? I am about to get a new one.
8 hours ago, Zero Knievel said:
Off the original ‘99 XX?
Yep.
PM received.
Gently used, 70K-ish miles. Not in box. Well, I will ship it in a box. $15.00 + s/h. Proceeds go to thehumanfundxx.
I’ve had the truck since ‘96 and no, the plugs haven’t been changed. I put 1 set of tires on it during that big Ford tire recall. A/C hasn’t worked in 20 years, both window regulators are shot, and no windshield wipers. It is used as a trash hauler mainly. Long bed free trucks are not cheap to come by, so I owe it to her to tune her up.
21 hours ago, superhawk996 said:
I'll take a set!
I'll PM you my info.
I have been putting off changing plugs, wires, and rotor cap. Have a feeling that after 25 years and 114K miles I shouldn’t put it off any longer and it will not get any easier. Probably bought parts twice and just forgot.
Will try to get it out the next few days.
Gas Tank Question
Small is a realtive term, of course, but I get your drift. This is a nekkid tank, so no hoses or fittings to get into. Once I put them in, I will use air pressure to knock them around, and a magnet and vacuum for removal.
